Question about E-Machines eMachines Desktop PC
Need to transfer OS and data files from Failed Harddrive. is this at all possible?
  • 59 Answers
It will depend if the hard drive is readable at all. A repair tech can try to plug it into a shop pc and see if it loads, there may be someone out there who can recover from a failed hdd, but it is not really likely if it cannot be used at all after being plugged into a shop pc.
Posted on Apr 08, 2011
Testimonial: "Thanks I kind of Figured that . was hoping my data Transfer kit might help with the problem ...but Thank you again."
    Problem Solver:
  • 7 Answers
You can't transfer the os, but if you buy a HDR caddy you maybe able to plug it into a new pc to recover your data. Does your hard drive make any noises?
Posted on Apr 21, 2011
THE COMPUTER WAS RESTARTED AND NOW IT WILL ONLY LOAD INTO THE STARTUP REPAIR MENU AND THEN INTO THE ADVANCE RECOVERY OPTIONS. I DONT HAVE A BACKUP SAVED. WHAT CAN I DO
You could have a corrupt os or a bad hard drive. In both cases it is still possible to get data off the drive just a matter of how much effort or money you are willing to through at it. The easiest way to recover the data is to purchase a external harddrive holder
.http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007705%204093&IsNodeId=1&name=%2410%20-%20%2425
Remove the harddrive from the laptop located on the bottom of the computer usually held in with two screws. install the harddrive into the hard drive enclosure and connect it to a working computer to see if your files are still present. transfer them imediately to the working computer if they are there. After the transfer insert the hardrive back into the laptop and test the hard drive with dft.( a bootable cd to test harddrives) IF the drive passes the test then use the recovery to restore the computer. here is a link to the drive fitness test.
http://www.hitachigst.com/support/downloads/#DFT
If you didn't see your files while connected to the coputer using the encloser then you can still send it off to cali for data recovery services but it will cost atleast $500 Datalifeguards is one I know of.
May 15, 2011 | Toshiba Satellite C655-S5049 Notebook
If windows vista has failed on a samsung laptop is it still possible to retrieve files from the hard drive, if so how is this done?
Yes of course.
However the procedure is somewhat advanced and is better be done by an expert professional.
Also please note that if your laptop is under quarantee then trying the following steps can void your warranty.
However, you can try the following:
First of all you will need an external hard drive casing.
Turn your laptop upside down and unplug it from the power and remove the battery.
Then unscrew the screws where the harddrive is.
See this link for an image of where the harddrive might be and look like
(HARDDRIVE)
After you unscrew the small screws remove the plastic cover and you will see the hard disk. Genthly remove it and place it in the external hard disk casing for 2.5" drives.
Then you can plug in the casing via usb cable in another computer and transfer your data.
Jan 28, 2010 | Samsung Q310-34P Mobile Notebook
Transferring Files from Mac OSX HDD to WinXP
the two harddrive config is different from each other..you can only open the harddrive mac to a mac pc to transfer the data..to make the hd usable to xp you have to convert the hd to xp format but it erases everything on the hd...
Aug 31, 2009 | Microsoft Windows XP Home Edition
When I plug in my 320GB My Passport Western
It seems your HDs left over portion which is not showing is not formatted for the particular OS in which you are trying to copy. It is advised to backup your HD contents and format the HD with the OS from which you want to take data in the same FAT system which that OS is using.
Jun 15, 2009 | Western Digital Passport 320GB External...
I can't repair bad sector in my harddrive?
You should immediately buy another hard drive. Reload the new one with your OS, programs, drivers. Cable Select them with the new one as master and old as slave. Transfer your data files to the new hard drive. Do this before it's too late and the drive crashes completely. It's only a matter of time.
Nov 21, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
How to reformat without loosing wanted data??
best way to do this would be one of two options.
First copy all your wanted data onto a CD / DVD (DVD RW best) and then once you've reformated your pc copy them back onto your desktop
The next option would be to buy an external harddrive. These are great because you can just move all the data you want back and force between your computer and external harddrive. This might be your best choice but it is a bit more costly
Oct 09, 2008 | E-Machines T3256 PC Desktop
I've purchased a belkin usb 2.0 file transfer cable for transferring old files from a pc with windows 98 to a new laptop with vista, the transfer cable is not picking up the two computers on the old screen...
Hi
Im not sure you can transfer over a USB cable with different OS and filesystems. easiast way is to buy a usb harddrive or usbstick copy data to that. or if the old computer have a networkcard to transfer over a crossover cable or true a network Hub/switch..
Aug 13, 2008 | Belkin Computers & Internet
Adding mor memory
A laptop can only have a single internal harddrive but you can replace your current drive with a larger one. The cost will depend on the size of the drive... goto the dell site and get your drive specs then goto a hardrive manufacturer site like Maxtor and see what size drives are avialble with the same specs ... you will have to backup and transfere all your files and also reinstall all of your applications and OS...
Apr 06, 2008 | Dell Inspiron™ E1505 PC Notebook
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Hard disk formet
Formating harddrive doesnt mean you already lost your data. It is being converted into binary file so there is possible to recover. The problem is you need to buy a data recovery to recover all the data lost in your harddrive.
I can help you but you need to buy the recovery for $99.00. Gurranted money back if the problem did not meet your requirements.
Rate me SOLVED!
Philip
Nov 19, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
