Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I have a weedeater lawnmower with a 5.0 briggs engine. It will start with just a couple of pull but won't keep running unless there is a FULL tank of gas. changed gaskets and then carb---still same problem--oil fine--new gas--anything else I can try?
  • 7 more comments
  • Roy Cagle
    Roy Cagle Apr 08, 2011
    Is there a clean NEW carb on this engine? Post back. I want to help. I will see your comment and reply.
  • jiminark Apr 09, 2011
    brand new so is the gasket--also changed spark plug
  • Roy Cagle
    Roy Cagle Apr 09, 2011
    Is this a unit with the gas tank on top of the carburetor...in other words, it uses what is is called a diaphragm carburetor, not a float bowl type?
  • jiminark Apr 10, 2011
    yes it is ----
    well didn't read that right ---carb is on top of gas tank
  • Roy Cagle
    Roy Cagle Apr 10, 2011
    My mistake. I see. Have you checked the settings and adjustments on the new carburetor? Have you checked the filter screen and pickup tube in Figure # 6 in the following tutorial? That may explain part of the full tank only operating conditon. Post back please. http://outdoorpowerinfo.com/repairs/brig...
    I will admit to I've never serviced one of these diaphragm carbs.
  • Roy Cagle
    This Briggs troubleshooting guide lists a "warped fuel tank" as a possible cause for the engine to not continue running. A guess a good flat-edge is needed here...loose screws are also mentioned...a vacuum leak of this sort would cause this. Here is the trouble table: http://www4.briggsandstratton.com/miscpd...
    couldn't access that site but sounds feasable---will check and let u know
    just so you will know this carb is plastic single unit with no adjustments
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Does it stop fuel level always the same in tank this really sounds like a vacume leak
Posted on Jun 24, 2014
freetek
  • 5568 Answers
SOURCE: Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Posted on Mar 22, 2009
SOURCE: Briggs and stratton 4.5 hp ( 10G902 ) starts great
Try draining the carb and gas tank into a small plastic bowl and look for water in the fuel. I you have a diaphragm type carb it might just need a new diaphragm and spring.
Did the stumble start right after refueling? If so then your gas can may be carrying some water too. It happens. I have seen gas can with INCHES of water in the bottom! True story. I went to a customers house after she had both her walk behind and rider stop running. She said both were fine until she refueled and then...no start. I looked at her gas can and it was terrible!
If you are trying to clear the main jet you need to get inside the carb and clean from the fuel inlet side. Bowl carbs usually have removeable jets that you can look through.
Good luck and be careful!
Posted on Jul 13, 2010
SOURCE: briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Posted on May 17, 2011
SOURCE: How to change oil in a Briggs Strattton 550
Under side. There is a lone bolt under the blade
Posted on May 28, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a Bolens Model
Hi JustSomeDude...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank and run for short periods of time.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 27, 2011
Suddenly cut out whilst mowing the lawn. now wont start, pull cord stiff to pull
Something just like this happened earlier this year with my pressure washer. This is what I did to fix it and now it runs great. Check the oil. If it's black or feels the least bit tacky, drain a pint or two of the oil out and re-add that amount of Marvel Mystery Oil. Now, attempt to pull the cord all the way out, but slowly at first. It should get easier to pull after about 5 pulls. If the mower restarts, let it run for 10 minutes until the Mystery Oil is hot and has cycled around inside the engine. Then drain that oil and refill it with a quality brand of oil. To top it off, either clean or replace the air filter, and put a shotglass of Lucas gas & injector cleaner into the mower's full gas tank. I also do this to my lawnmower and weedeater. It works wonders. BTW...If you're unable to turn the engine over by pulling the cord, remove the spark plug and tilt the mower up, so you can turn the blade easily by hand (use gloves). BUT FIRST MAKE SURE THAT SPARK PLUG IS REMOVED. REMEMBER... SAFETY FIRST! Let us know if this helped you any.
Jun 29, 2014 | Garden
Tip
To every one that owns small engines,mowers,weedeaters,ect
ah spring is in there air time to break out the lawnmower,weedeater,chainsaw,ect somebeach it worked great the last time I used it pull,pull,whats going on pulled so hard i broke the cord got gas went and bought a new plug still nothing swich on fullchoke honey weedeater gone bad honey i need a new chain saw cheaper to by a new one than to put it in the shop now the real problem when you put up that weedeater,that cool tiller,that awsom chainsaw the one thing you did not do is drain the exess fuel when you store this equiptment for extended periods of time drain the gas in a safe manor start that weedeater , chainsaw, ect and run it completly out of fuel ya see when gas or oil&gas mixtuers sit they evaporate leaving a laquor like substance gumming up your fuel/air mixture needle&seat floats nasty stuf next thing you know theres me driving through your neighborhood picking up your weedeater,that cool rototiller ,nice lawnmower dude yess now rebulding a carborator can be a pain sometimes but if you have patients it can be done get a can of carborator cleaner with extension hose clean the outside of the carb so you can see what your doing and not getting trash where it dosent belong check your fuel lines they tend to get hard and crumble take one hose off at a time some only have one but most have two spray cleaner back twords tank see cleaner in tank cool next spray cleaner into fuel inlet a couple of bursts reconect hosess spray cleaner down carb air intake pulling on throttle to open choke flap for a deeper clean now assemble go through normal starting prociedures still a problem now it gets deep you have air/fuel mixtures screws ,diaframes if you dont feel safe about getting deeper into that carb go to lawn mower shop with ser# how many cc maker of carb stamped on carb most likley a warbro tell them you want a rebuild kit not expencive and schematic I would like to tell you a lot more but there are so many varables its crazy so going back to the begining DRAIN THAT EXCESS FUEL START THAT ENGINE TILL IT COMPLETELY RUNS OUT BEFOUR YOU STORE you will be a lot happier so will your wife .!!!zaper!!!
on Apr 14, 2010 | Garden
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
Sep 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
I stored my Briggs and Stratton Murray 4.5 Lawnmower at an angle and oil came out the exhaust.
Just let the mower sit on the level for a while. Then be sure to check the oil level before starting the engine. It'll probably blow some oil smoke, but then it should clear up and be fine. You should only tip your mower in one direction, ever. That is down on the handlebars; up on the front. This way, the fluids have no where to run. Also be sure the gas tank is not full or fuel will run out the vent in the cap.
Oct 09, 2011 | Briggs & Stratton Briggs Stratton...
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. ...
this is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Nov 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawnmower was overfilled with oil.It has not run that good since,but I could still mow my lawn with it. Then later on it started to die out. and it won't keep running. I had it looked at, and it still...
It may have damaged the piston ring lands (grooves) by slapping the piston with oil. If you have the compression tested it will tell you a lot, the mower should be around 100 - 120 psi, anything less and the engine is likely not worth repairing, if you like the mower buy a short block.
May 31, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
222 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
