Question about Mantis 4-Cycle Tiller
My Mantis Tiller won't start and there is grinding type noise when I try and start it. I recently did some very lengthy trench digging over a period of about 2 months.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
It sounds like the clutch springs may be overheated and the clutch shoes rub while you try to start it.
If you loosten the screw that holds the engine to the gear box you can try to start it without the clutch and see if that is it.
Good luck
Posted on Apr 08, 2011
Need to know oil / petrol mix for Mantis 2 stoke Tiller
it is a 50:1 gas:oil mix. I'd also strongly recommend adding a fuel stabilizer to the mix, as a tiller has a tendency to sit for long periods without being used. Good luck!
Nov 17, 2012 | Mantis 2-Cycle Tiller
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Starts and runs but tines won't turn
check for a damaged gear or shear pin
Apr 25, 2012 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I used my mantis electric tiller for the first time today and more times than I can count, it didn't grab into the earth and came racing back on me very quickly-the earth was pretty hard but I was...
a mantis tiller is low end. It does not have the weight to do any real tilling. Granted they are all gonna be hard to control, but unless you have, a bed that is soft soil , it will not work.
Mar 26, 2011 | Mantis Electric Mini Tiller/Cultivator
We purchased a mantis 2 cycle garden tiller new and have only used it 3 times. it has only been used maybe 1 hour total and now it wont start at all. what can we do to get it to start?
Empty mantis fuel tank. Remove and check spark plug. Replace with Champion CJ8Y or NGK BPM7Y if necessary. Gap is .6mm - .7mm or .024" - .028". Prepare fresh fuel/oil mixture. Add fresh fuel to tank along with 2 ounces of 100% acetone (available at walmart) - this will remove deposits inside of mantis from sitting for prolonged periods. Try to start several times. If unsuccessful let mantis sit for a while. Do this several times if necessary. Eventually it will try to start. If it will not remain started then you are successful in completing the previous section. Next you need to watch this video and do what it says. It is actually quite simple.
http://www.alamia.us/mantis_parts_s/148.htm
Feb 04, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I did a tune up on my mantis tiller, plug, air filter, fuel filter, carb adjustment, the darn thing idles but want throttle up, is it ready for the trash,,,,
It is easily remedied. Watch this video:
Also, always run mantis out of fuel before letting it sit for any period of time. If it does sit, put a couple ounces of 100% acetone in the fuel tank (available at Walmart) with some fresh fuel/oil mixture. This will remove the varnish inside the tiller.
Jan 08, 2011 | Mantis 2-Cycle Tiller
Where do you set the whells so tiller doesn't dig trench & I have to lift it out?
you have to pull these machines toward you. They don't work the way that you think they should. hope this helps you...
Sep 28, 2009 | Craftsman Gas Mini - Tiller/Edger
4 stoke mantis tiller, loud noise not in engine, maybe the clutch
If you can get to the dry bushings, DuraLube pump lube will fix your problem. It is available at most automotive stores and departments for $8 -10. I've used it in areas where I had to lube every 10-20 working hours. Now i can go 200-300 working hours. You can also add 2 or 3 ounces to your crankcase oil.
Jan 29, 2009 | Mantis 4-Cycle Tiller
Mantis 4-Cycle Tiller Logo
193 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
