Question about Exercise & Fitness
My Avanti AT380 treadmill is displaying an error code on the console that is not in the manual - a back to front 'J'JE1. Is there any way to reset the machine??
    Problem Solver:
  • 14 Answers
Replace the belt, flip the deck and replace lower electronics. Your way past belt change.
Posted on Apr 09, 2011
Error 4 on my avanti 380
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. Check for treadmill error codes
Mar 13, 2016 | Avanti Fitness AT380 Treadmill
Avanti AT 380 gets an error code 68
556a61de-db92-4886-91ce-2e6c36b807f6.gifyou must LUBE the deck belt, front rollers and rear. This happen because the electronic system , shut down for to protect the system.
see the video and proceed according. See the diagram for REED switch clean it, test for open or faulty, tight the connector very well.
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
Treadmill error code 68
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Suspect upper panel faultr,shows En9 in r/hand[speed]window at start up
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you
Apr 03, 2013 | Avanti Fitness AT380 Treadmill
I purchased a avanti 380 treadmill from eBay. Was running perfect so we put it in our trailer and brought it home. When we plugged it in it had LJE1 displayed in the time display and flashes 68 in th
Adjust the REED switch, see the diagram, clean it, tight the connector very well
2) replace the battery well, clean the contacts, retight the spring contacts with pliers very well.
and proof again. God bless you
Sep 06, 2012 | Avanti Fitness AT380 Treadmill
I need a user manual for Avanti AT380 Treadmill
http://www.manualsnguides.com/results.php
www.iconservices.com
http://fitness.manulsonline.com
http://manualsfactory.com
since this place you must not find the exactly model, you must pay in some of them, and download something similar.
The problem is the factory is coming in australia, and there are not service in USA, and support. sincerely.
Do not waste your time searching in the WEB.!
E.CUADRA
MANAGUA NICARAGUA
Dec 01, 2011 | Avanti Fitness AT380 Treadmill
I didn't receive my instructional or users manuel for my Avanti AT380 Treadmill
GO THIS WEBSITE AND DOWNLOAD SIMILAR MODEL FROM AVANTI USER GUIDE:
http://www.manualsnguides.com/results.php#.TtV56Xpc71s
SINCERELY
Nov 29, 2011 | Avanti Fitness AT380 Treadmill
I didn't receive my instructiona; or user manuel for my Avanti At380 treadmill. Where can I get a hard copy or on line copy?
http://www.manualsnguides.com/document.php?iddocument=Dwhbzqg9ue#.TtYPiXpc71s
User's Guidegreyline.gifAVANTI
928S
Treadmill AND DOWNLOAD AND YOU MUST PAY FOR IT. YOU DO NOT HAVE ANOTHER SOLUTION. AVANTI IS DOES NOT ANY WEBSITE WITH CUSTOMER SERVICE. ONLY COMPANIES THAT SELL THE EQUIPMENT BUT WITHOUT TECHNICAL SUPPORT.
SINCERELY.
E.CUADRA
Wont work AT380 AVANTI tred mill - comes up EJJ SOMETHING OR OTHER PUSH BUTTONS DONT WORK
ADJUST THE REED SWITCH ACCORDING WITH DIAGRAM.
NOW TIGH THE FLEXIBLE CORD FROM KEYPANEL VS DISPLAY BOARD AND THEN CONNECTOR FROM DISPLAY BOARD VS LOWER BOARD OR MAIN CONTROLLER BOARD.
11_30_2011_12_40_41_am.gifIf you can open the keypanel and clean with contact cleaner will be a good idea with carefully and patience. sincerely.
Finally if the problem persist you will 2 options: a) faulty display board and 2) Main controller board.
E.CUADRA
MANAGUA, NICARAGUA
Aug 21, 2011 | Avanti Fitness AT380 Treadmill
When turned on right hand display comes up with 51 then flashes with the number 68. Dead man button works but not any of the controls. Alex
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_12_46_08_am.gif
Try to tight the keypanel flexible cable vs Display Board and then tight the connector from display board vs Main controller board(lower board) and will be a good idea spray with contact cleaner the keypanel with carefully and patience.
Finally you will have 2 options if the problem persist: 1) display board faulty or 2) main controller board faulty. See. the block diagram how the main controller board has 90% of function in any treadmills.
Jul 14, 2011 | Avanti Fitness AT380 Treadmill
Exercise & Fitness Logo
216 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
