Home | Bosch | HCBG500, 5 Pc Industrial Hammer Drill Bit... | Gets very hot and smokes
Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
Problem for Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
By layohernande on Aug 06, 2008
while i am using it the drill get hot and starts smoking, therefore i have to stop using once that starts going on
Same Problem
Oct 23, 2008
-   after a few seconds of masonary use the drill started smoking
i stopped using the drill. later when i turned on the drill on no load the speed (rpm) quickly dropped & creepingly rotated with no torque-   anil_saraf_o
Solution #1
posted on Sep 02, 2008
Not Rated)
AlmostBob
Rank: Guru
Rating: 88%, 503 votes
cooling holes blocked
drill is being used at too hi a pressure, so the bit does not clear debris fast enough,
bit is blunt, even diamond drills blunt
the objuect being drilled is a composite, and some part of the composite is flammable
using a steel twist bit where a carbide impact bit should be used
not solution just some things to check
Comments:
Sep 02, 2008
- drill is overloaded on the job attempted
another thought
Was this helpful?
Yes
No
Popular Solutions for Bosch HCBG500, 5 Pc Industrial
Questions and Unsolved Problems for Bosch HCBG500, 5 Pc Industrial
Do you recommend Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set?
Answer
Answer
my wicks cordless hammer drill always in hammer mode. i can turn the dial to normal drilling mode... (More)
Answer
quando estou usando a furadeira c a ponta da broca p baixo ela faz um barulho estranho como se... (More)
Answer
My bosch hammer drill will not hammer? How can I repair the problem?
Answer
Can you tell where I can Buy one of the New Bosch 4-32 DFR Rotary Hammer Drills in Sydney, Australia... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch HCBG500, 5 Pc Industrial...:
Top Drill Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Drill Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
