Question about Mercury P4VM800M7 Motherboard
No signal on mother board when i turn on the computer, no booting, no sound of step booting, but the fan work.
  • 59 Answers
The motherboard lights should turn on. First step make sure the hard drive isn't bad, see if you can hear it trying to run. If that isn't the issue you will probably have to replace the motherboard.
Posted on Apr 08, 2011
Computer is not booting to windows
Reseat the ram. If that doesn't work, try reseating whatever you can --without shorting out the chips. Follow proper procedure for not frying your setup with static electricity while you do this.
Here is a link offering the possible fix and/or some company in similar situations.
Computer fans turn on but nothing else
Sep 18, 2017 | Computers & Internet
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
Aug 03, 2010 | Acer (ACERMOTHERBOARD)
No signal to monitor. no beeps at start up. fans running. new video card installed (after issue began) monitor & cord are working fine (have checked both with other computer)
check your RAM (random access memory) m sure your ram is not working
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Mar 26, 2010 | E-Machines eMachines Desktop PC
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
Desktop
most likely your guess is correct and if a beep sound is not availabe (Power good signal) than its 100% power supply problem.
Apr 26, 2008 | E-Machines eMachines Desktop PC
No Boot
if u didn't get any thing on display even check signal cable the problem is in the monitor
or you are getting check signal cable the problem is in the mother board or Ram first change the ram even thou you are not getting display change the mother board
Apr 16, 2008 | Computers & Internet
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
