Connected computer to tv. it said no signal when i pushed the enter button
  • 42 Answers
From the TV source or input menu you must select the input you wish to use. If using a laptop or PC you may need to switch it to using an external display device.
Posted on Apr 08, 2011
XCAN'T FIND THE BUTTON TO RUN CHANNEL AUTO SCAN
First make sure that the Source is set to TV and a good antenna/coaxial cable is connected to the TV. Use the Input button on the TV (to the left of the power button) or the Input Select button on the remote. Use the up/down arrow keys to navigate through the source list and press Enter to select that choice. (On the TV, the Input button is the Enter button.) Next press the Setup/TV Menu on the remote (or Menu on the right arrow button or Enter. Then go down to Auto Ch Memory and press the right arrow or Enter. With the up/down arrows, navigate to Signal Type and set that to Air (for OTA channels) or Cable with the left/right arrows. Now navigate to Automatic Search and press the right arrow or Enter. Wait for the scan to be completed.
I hope this helps. The steps are shown in the manual for the LT-19D610 on page 18. The manual is available from JVC on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL028825 . The direct link to the manual is http://resources.jvc.com/Resources/00/01/47/J55D0221B.pdf .
Dec 05, 2015 | JVC LT-19D610 19" 720p 1366 x 768 35000:1...
How do i hook it up to my computer without a remote
"How do I hook up my computer without a remote?"
Two possibilities come to mind:
1. With a VGA (15 pin), HDMI, or DVI connected computer there should be a keyboard key combination (typically a Function button (Fn ) and one of the F1 thru F12 keys) that will activate the option for switching the video signal to the external monitor/TV, or in the case of a laptop, viewing the image on both screens. The TV's "INPUT" button, if there is one, will need to be pushed several times to cycle through the available input signals until the computer video signal input is seen.
2, Alternately, if there is no "INPUT" button, it may be possible to purchase an inexpensive universal remote (ones seen even at a local $1 Store) in able to access the TV menu. The remote will have programming instructions and codes for most major TV brands, and an Internet search, or the TV manufacturer, should provide for additional codes for your specific TV model if necessary.
Kindly post a reply if either of these options do work for you.
May 27, 2013 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Install computer to insignia tv
try to unplug the set for a while?
Jun 08, 2012 | Insignia Televison & Video
Tried to use roof antenna on RV. My Sharp hdtv by passes the digital setup. How do I receive the over the air digital signal
Used the tv remote.Push the menu button.Now u are tv menu.Goto SETUP,go down to CH SETUP push enter on the tv remote.Pick AIR not Cable and push enter on the remote again.Now tv go in auto scanning.After it is done searching all cannels,ur tv will get all the free DTV air broadcasting channels.
Apr 17, 2011 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2,3..so on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
How to get my tv off of video mode
Take the remote, go to menu, scroll down until you find picture settings, continue until you find ant catv, push the right arrow until the cursor is over catv, press enter, that should restore your regular channels.
Jan 13, 2011 | Sanyo DS31590 31" TV
When I connect my Toshiba L505-S6946 to a Samsung TV via a VGA port, the computer screen goes black and the TV says signal not supported. Could anyone help me? I know they are talking since when the...
Try pushing the FN button, next to the left CTRL button, and then hit the F5 key at the top. By the number of times you hit the F5 button, you are telling the computer to display on its lcd screen, on the monitor (TV), both, or neither.
Dec 12, 2010 | Toshiba Satellite L505-S5966 Notebook
I have a Sanyo DP26746 TV. I pushed the reset button in error and am unable to get to any other screen. It wants to look for HD channels. Since I only use a satellite service it can't find any. Help! I...
First of all make sure all the leads are connected to the TV.
Press the reset button on the remote twice (this will clear all previous settings) and perform a channel search and create new ones.
Now you will need to perform an all channel search.
Press the Menu key to display the main menu.
Use the cursor up/down keys on the remote and select "All Channel Search" and press enter. Use the cursor key to select yes and press enter.
Now you may need to perform a digital cable search to pick up your satelite digital signal.
Press the tuner key on the remote and then the menu key.
Use the cursor key to select Digital cable search and press enter.
Now the TV should scan for a digital signal
Good luck and kind regards.
Jun 25, 2010 | Televison & Video
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
