Question about Intermatic 24 Hour Outdoor Timer HB31R
Product: Intermatic 24 Hour Outdoor Timer HB31R. After many years of service, this unit suddenly stopped working. The unit was always turned on manually and allowed to shut off at a specified time . . . 2-4 hours. It is used to run an irrigation pump. We plugged the unit in, turned it on, and checked the outflow plug with a volt meter . . . nothing. Is it fixable or does it need to be trashed? Many thanks for your input!
My Tork 1101 24 hr timer has stopped working. I hear it running, but the clock will not turn. I have to turn it on and off manually for my pool pump. This happened 2 years ago, then the following year...
You might need $45 clock motor for for Tork 1101 120Volt.
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Open following link to identify timer and see replacement clock motor and trippers:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Intermatic crossover shows T101 timer replaces 120Volt Tork 1101.
Amazon sells new Intermatic timer for $45 with super shipping
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Crossover wiring from Tork to Intermatic:
Black wire on Tork L and 1 connect to Intermatic terminal 1
White wires on Tork X connect to Intermatic terminal A
Black wire on Tork 2 connects to Intermatic terminal 2
http://waterheatertimer.org/How-to-wire-T104-Intermatuic-timer.html#T101
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 04, 2011 | Vacuums
I need replacement clips to a hb31r timer, were can i find them?
I have 2 links to plastic Intermatic trippers.
I search timers each day, and have not run across a different plastic Intermatic tripper.
images on page will let you compare with your tripper:
http://www.westsidewholesale.com/timer-switch-tripper-sets-red-on-and-green
http://www.hottubwarehouse.com/ProductDetails.asp?ProductCode=156PB10398A
If this tripper is correct, add a comment and help fixya community give this information to others asking same question.
If this tripper is incorrect, then HB31 tripper may not be available.
Large number of timers do not have replacement trippers.
You can also take advantage of fixya phone support.
Expert can answer your question for a price.
Dec 25, 2010 | Intermatic 24 Hour Outdoor Timer HB31R
Intermatic Timer Model HB1116R - Timer Clock Inoperative, unit is one year old.
1) Manual says: If within (1) year from the date of purchase, this product fails due to a defect in workmanship, Intermatic Incorporated will repair or replace, at its sole option, free of charge. This warranty applies only to the original purchaser and is not transferable.
2) Contact Intermatic
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 11, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My HB31R runs slow. Is there any adjustment ability to the timer mechanism to achieve a correct 24 hour timer.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb31r.aspx
HB31R heavy duty 1800 Watt outdoor plug-in timer is one-piece unit that does not come apart for repairs.
Usually with these mechanical dial timers, when the clock motor starts getting weak, the timer dial starts to stall when tripper meets on-off lever.
And then timers runs slow.
At this point, the little plastic gears are getting stripped out, or the clock motor is overheating.
In either case, the clock motor is spiraling downward.
If this is new timer, take it back.
If this is older timer, the manual and fact sheet do not show a warranty.
New HB31R on ebay for $15
http://compare.ebay.com/like/250558888618?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=181711814537&crlp=1_263602_304662&UA=WXF%3F&GUID=c8511cb512c0a0aad3e705a7fffd84ab&itemid=250558888618&ff4=263602_304662
Woods makes 1200 Watt outdoor timer, but lighter weight than Intermatic:
http://www.amazon.com/Woods-59204-Weather-Outdoor-Repeats/dp/B0014WRNNK
With larger heavy duty outdoor timers like the Intermatic T-101R outdoor 120Volt timer, you can buy the clock motor separate and replace when clock goes bad. And you can buy the trippers separate. However T100 series timers are not plug-in, they are hard-wired. T-101 is made to last 10-15 years, but cost $60-70. My local Lowes sells them in stock for less.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Dec 08, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How do i set my model hb31r raintight timer for using out doors
Open following link to identify timer and download manual:
Manual has too many words than fixya allows for free answer.
So I cannot copy manual here.
However you can add a comment any time and say exactly where the manual is confusing. I will respond back and help if possible.
Nov 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My Intermatic Timer (model PB115M1) is not keeping time. Without any electrical load it is loosing 3 hours every 24 hours. Its part of an older Intermatic Malibu yard light transformer. Is it fixable or...
...may have solved this one... opened up an Intermatic Model HB31R and it seems to have the WG2030 timer motor... this model (complete timer box) cost $20 or so...
Jun 19, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Where to find intermediate gear -about 1/2 " in diameter.
The following is a link to the only site I have seen that sells just the gears for the Intermatic timer clock motors. I took my clock motor apart and this was the gear that was bad. The first link is to the site and the second link is to the picture of the gears to make sure it is what you are looking for. http://www.stuartsinger.com/ballclock.htm#Replacement Parts
Picture of gears: http://www.stuartsinger.com/Ball%20Clock%20Web/Ball%20Clock%20Pics/Gears.jpg
Hope this helps, Chuck
Jul 31, 2009 | Intermatic 24 Hour Outdoor Timer HB31R
Intermatic 24 Hour Outdoor Timer HB31R Logo
377 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
