Question about Royal VF810 Shredder
Making a humming noise when paper is inserted
G35 making humming noise from under hood
could be power steering pump,altenator or belt tensioners or idler pullys.
Nov 06, 2013 | 2004 Infiniti G35 Sport Coupe
My HP LaserJet P4015n is making a high pitched noise when I print. It is also printing very slowly.
Same thing happened to mine at work. All because the paper tray indicator was not exactly on 'letter' size.
Remove the lower tray and remove all of the paper. Insure that the 2 paper size selectors are exactly on the marks for the size of paper you are using.
My HP4015N is now running at full speed with NO ANNOYING HUM!!
Nov 10, 2010 | HP LaserJet P4015N Printer
Speakers are making a humming noise
If the noise is accross all channels then it's most likely the large electroltic capacitors in the power supply. These filter out the mains hum 50/60hz. There might be two or more they will be the biggest! Even if you can determine only one has gone, it's best to replace them all.
Jul 12, 2010 | Kenwood VR-407 Receiver
X5470 lexmark has paper jam now makes squealing noise when I use it!
Try this. Remove any paper jams, take out all sheets of paper and remove all cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. The printer will print an alignment page. Load just 5 sheets of paper only. Let it print the alignment page all the way through without cancelling it. If printer is not making the squealing noise, problem resolved. If it's still making the noise, the printer's mechanism somehow got affected by the paper jam now. If that's the case, any mechanical/hardware problem in the printer, it's better to ask assistance from Lexmark. If printer is damaged already, and it's still within warranty, they might send you one for replacement. Good luck!
Apr 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
Paper is not being picked up and fed through.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 20, 2009 | Canon PIXMA MP510 All-In-One InkJet...
The noise is a hum or buzz. We've narrowed it
By chance have you tried making sure the laptop is not too close to the speakers? Sometime you will get feedback when the source is to close to high powered speakers. Also, check your jack cord and make sure no splits/cuts are visiable and the plugs are fully inserted.
Good Luck and keep making great music. Aloha.
C2Solutions
Sep 02, 2009 | Dell Inspiron 6000 Notebook
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Jul 16, 2009 | Microwave Ovens
Printer R300
make sure you have the paper where it hits the part that sucks in the page to be printed (you can see the gray stucture by removing the paper and looking into where the paper is put) this might cause your papers, if you have a small amount, to bend to where the dip of the curve is facing the front of the printer. *Also the best way to prevent this is by having a LOT of paper where its fed (if the bending thing doesn't work.* Also the clicking noise is the sucking part not getting a piece of paper. This is because the paper not inserted correctly means that the pronter detects that paper is in the pronter but it can't get it.
Oct 15, 2008 | Epson Stylus Photo R300 InkJet Printer
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Noise/humming while cooking; especially popcorn; intermitent on other food
Popcorn is heated by a metallic insert in the bag. This causes some additional power consumption by the magnetron. It is no cause for alarm.
Dec 19, 2007 | Kenmore 80412 Microwave Oven
Royal VF810 Shredder Logo
47 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
