Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
I'm looking to buy a used Yamaha YG6500 Generator, how can I find the year that it was made?
    Master:
  • 403 Answers
Google it
Posted on Apr 08, 2011
I bounced the "H" out of my generator. When i plug something in it goes straight into overload and quits.
You may have knocked something loose inside. Take off the generator end cover and look for anything obvious. There is nothing to loose at this point.
Jul 22, 2014 | Yamaha 2400is Portable Generator 2400 Watt...
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
My Yamaha Ef2400iS inverter shuts off when I use my 3/8th electric drill. This problem started last fall. I could use the drill and portable saw, not at the same time, since the inverter was new three...
yes, the problem is that electronic/electrical components age with use. especially voltage regulators and switching transistors. as they age they can no longer sustain the current you are demandiing from the unit. the units are designed to run in the middle zone, not at full maximum load all the time, if you do that you will weat it out quicker. Always buy a power supply that is double your intended wattage and it will last many years. Hope this answers your question
Mar 21, 2011 | RTO New Yamaha Inverter Ef2400is / Yamaha...
My Yamaha 2400 is not running smooth and it lopes. It has about 40 hours on it. I cleaned the filter Air and put a little additive to boost gas. Also changed spark plug which was dark at the probe. I do...
40hrs? I'd look at the exhust.There is a screen that fits INSIDE your exhust.A small flat tipped screw driver should pry it out easy.In chainsaws they're used for spark arresters,the same on these I think.Quick wirebrush and your exhust should be able to flow and not back up.
I've had my 2400 7 yrs now here in Alaska,out in the woods where I live.I need a Boost Control Unit,teach me for not using a ground wire,I burned a pin out in my unit.$800 part for a $1,300 generator.I really really like mine so I'll buy another and keep looking for a used one online.
Dec 15, 2010 | Yamaha EF2400iS Portable Generator
What servicing can I do for my generator which has not been used for 2 years now YAMAHA GENERATOR EC5000DVE
change the spark plug clean the fuel tank replace filters and oil change fuel line if cracking or stiff.
remove carb bowl clean out with carb clean remove any sch-lack from old gas run and test power.
hope this helps
Aug 28, 2010 | Yamaha 4500 Watt Electric Start Generator...
Can I convert a Yamaha EC 5000DV generator to electric start? Where can I get those parts. rich
You can convert it BUT.... It will require spending almost as much on parts and shipping as this generator is worth.
You will need a new flywheel. Wiring harness for the start circuit, Key / switch assy, modified contgrol panel, Starter & solenoid, mounting bolts, a battery and battery holder. Additionally you will will need a voltage requlator.
Each of the parts will have to be special ordered from a Yamaha service center type shop. There is not a kit form for your unit. Depending on exactly which engine you have the 357 CC or the 410 CC you may not even be able to do it at all.
I just looked into doing the same thing for a Robin RGV 6100. "The dealers have you by the private parts!!!" The cost was about $200.00 less than buying a new generator of the equal size with an electric start system. The only thing I would not have had to buy for that conversion would be the regulator due to it being an inverter generator type unit.
Thanks for using FixYa.
Kelly
Dec 27, 2009 | Coleman Powermate 7,000 Watt 13 Hp...
Might Buy is there a problem with their reliability
I would look at the honda and yamaha generators. Their small gensets are unbeatable and rugged as they come. Dependable as sunshine.
But, that's just my opinion!
Best regards, --W/D--
Aug 11, 2009 | Sunpentown SPT TG-1000CA 1000 Watts 2.0 HP...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
333 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
