Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
My washing machine cannot turn on and the door is locked and will not open. No lights are not coming on . Clothes are locked in the washer, including my daughters jersey that she needs for tomorrow.
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Hopefully the info below will supply you with the info to get the door open for now at least...and a little more with some luck.
The door typically locks as a result of the unit failing to drain, so....
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) My washing machine cannot turn on and the door is - macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with theMy washing machine cannot turn on and the door is - macmarkus_32.jpgbr />
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but gettingMy washing machine cannot turn on and the door is - macmarkus_31.jpgirst if present is usually a good plan
Once the door is open and you've removed the items you wanted. Unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets".
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Apr 08, 2011
With 1 minute to go, the washer stopped and door locked light came on. Wet clothes are in machine and we cannot get door open.
To me that sounds like a suds problem. I have a service manual for you HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 29, 2010 | GE WCVH6260FWW
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
438 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
