Sound distortion ,even on low volume since new.TV only 3 months old
  • email929 Aug 06, 2008
    We are not using a DVD player
  • billy reynolds
    billy reynolds May 11, 2010
    do u have this sound distortion when using a dvd player
    Champion:
  • 232 Answers
TRY A DVD PLAYER TO ISOLATE THE BAD COMPONENT. IF IT WORKS CORRECTLY THEN THE PROBLEM IS IN THE TUNER AUDIO OUTPUT SECTION, IF IT DOES THE SAME THING THE SPEAKERS IN THE UNIT MAY BE DAMAGED. TRY TO USE A VCR TO GET AUDIO OUT AND RUN THE SIGNAL THROUGH A STEREO WITH STEREO INPUTS AND LISTEN TO THE SOUND IN THTAT WAY
Posted on Aug 11, 2008
Low output with high volume
sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Dec 23, 2013 | Pioneer Avic-940bt Car Navigation Cd/dvd...
Distorted speaker sound - only 18 months old not played at volume - is it likely to be the speaker or electronic ? Is this a common fault - will it happen again making this amp unreliable ? Not as...
this is a electronic problem. there must be a capacitor/s in the output section that's swollen and will keep giving the same problem unless its replaced.
G.
May 29, 2011 | Marshall Amplification Marshall AS100D 2x8...
I have to have the voume at 30 to get good sound
Try going into the menu and selecting the sound menu and resetting the sound to factory default..If this doesnt help matters you can change the sound preferences to custom settings..As long as the sound isnt distorted at low volume then this solution will apply..If the sound is distorted at low volume then your speakers may be faulty..sometimes caused by listening to the tv at full volume over long term which strains the speakers and prematurely ages them
Oct 17, 2009 | Samsung HP-T5044 50 in. Plasma TV
Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Sep 30, 2009 | Fender Hot Rod Deluxe Guitar Combo...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Sound Distortion
somekind of hardware side failure or bad drivers.
I hear sounds from my audio output if i connect my headphones there directly but when I connect it to my speaker system they filter the distortion.
Apr 13, 2008 | ASUS M2N-E SLi Motherboard
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Hitachi 27ax1b volume problems
If the audio is not distorted, but low. I would suggest a coupling capacitor from the audio processor to the audio output amp ic.
Feb 24, 2008 | Televison & Video
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
