Question about HP Photosmart C5580 All-In-One InkJet Printer
Hello- I am trying to print something from my computer and the printer is printing the very faint grey lines on the screen extra black on paper. I have not had this issue in the past and I have a sneaky suspicion my 2 year old hit a couple buttons. Please help.... it is a total waste of ink and the text that you can very clearly see within the faint grey lines is all covered in black after the print is done. Thanks, Ryan
    Guru:
  • 352 Answers
Unplug the printer, Uninstall and Reinstall the printer software and driver as below:
Uninstall the printer by Going to Control Panel, Printers and Faxes, Right Click the printer and Delete. Then Go to Control Panel, Add-Remove Programs and Delete any HP related Software.
If you have the disk handy insert in and follow the installation prompts, if not you can download the software from Hp.com.
I hope this solves the problem, if not it could be a print head issue. try cleaning it by following the instructions in the link below.
http://www.fixya.com/support/r3986425-unblock_print_heads
If this helps please rate my response. Thank You for supporting the FixYa Community
Regards GM
Posted on Apr 08, 2011
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Faint one inch wide line appears at the same time, every time.
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
Apr 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
Grey & Black Printing on everything
it appears that the printhead has a problem. try cleaning the printhead, via software. usually in printer prefs. also try running a few test pages. to see if you have any colours at all. if it,s only printing in grey scale. i.e grey-black. check the colour cartridges ink has,nt run out or blocked the nozzles.
Hope this helps Mike@Compurepair.
Feb 20, 2008 | HP DeskJet 9800 InkJet Printer
Black lines on photo
Are the lines always in the same places? If they are, then I would try using different photo paper. Humidity plays a big factor when printing with any kind of paper and buying new paper would be a good start. Make sure that the paper is made for your printer specifically. You might also try printing on plain paper to see if you get the same results.
Jan 17, 2008 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart C5580 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
