Question about Ford Garden
2N FORD Tractor Fuel will not flow from tank to
2N FORD Tractor Fuel will not flow from tank to carb. I have drained the tank and removed the sediment bowl assembly blew it out and cleaned it along with the fuel line to carb. If i loosen the pressure on the sediment bowl nut or remove the inlet line to carb fuel flows. I also drilled an 1/8 inch hole in fuel cap incase vent is clogged
  • outdoorsm73 Apr 08, 2011
    thanks I'll do the cleaning of the carb bowl in the morning, i just bought the tractor . We drove it 81/2 miles to the house. it has been running fine and easy to start untel i was blading the driveway. one time it would get fuel then it wouldn't. i cleaned the screen in the sediment bowl many times nothing blocking any more
  • 3,740 Answers
You have a clogged fuel manifold in the carb. This is usually caused by something in the float needle seating area. Remove the float bowl, remove the float and pull out the float needle. Then use carb cleaner in the float needle area to blow out the debris or dried / varish in the float needle seat and the fuel maifold. Spray carb cleaner from the manifold / hose fuel connection and make sure that you get it clean. Then with the float and float needle still removed turn on the gas and make sure you have fuel flow.
Here is a carb kit if you need parts:
http://www.8ntractors.com/carburetor_repair_kit_c545v_1035_prd1.htm (Do a net search for the kit you can get them cheaper than this one.)
I get the feeling that this tractor sat ilde for sometime and your now trying to get it going again. When a fuel system sits for a very long time with fuel the fuel in the float bowl and carb will turn into a shellac and really gum things up. Worst case you remove the carb and soak it in Chemtool B-12 overnight / couple of days then rebuild it using the kit above. (You will be glad that you did!)
You can get a new fuel cap here:
http://www.8ntractors.com/ford_2n_tractor_fuel_tank__cap_343_ctg.htm
Also there is a SCREEN in the top of the fuel sediment bowl that can be caked with gunk. This will stop all fuel flow if it is blocked.
http://www.ytmag.com/store/parts/pics/wm_2NAA916061_.jpg
I have spent hundreds of hours on one of these... doing large garden work back in the day and moving hay in several different ways. (Brings back some good memories and makes me ponder where that tractor is today...hmmm..)
Thanks for choosing FixYa,
Kelly
Posted on Apr 08, 2011
Testimonial: "Fuel flow problem resolved after the carb was cleaned and rebuild thanks for the quick responce."
  • 1 more comment
  • Kelly
    Kelly Apr 08, 2011
    Had yet another thought from experience.
    You may also end up removing the fuel tank or at least disconnecting everything from the fuel tank to clear debris in the fuel tank port. My experience is to remove the tank, empty the contents and then shoot air across the opening WITH THE TANK INVERTED to draw out any debris. Have had to do this with Ford, Case, Allis-Chalmers, Minneapolis Moline. Oliver, Farmall / International Harvesters and John Deere models that have sat for long periods. Just could not stop the intermittent fuel flow until the tank was also clean. I am always reluctant to introduce air directly into the fuel outlet port for fear of damaging the tank or fitting. (Been there done that!)
    Kelly
  • outdoorsm73 Apr 17, 2011
    Kelly thanks, Well just been able to put the carb back on the tractor . The mounting studs stripped . Was not able to tighten down. Ended up buying thread all and able to thighten down. B ut believe i found the correct size studs last night at summits racing parts for carbs. After i turned on fuel . Tractor started and shuts after running for a few minutes. So i have cleaned out jet and seat area twice . it will restart shut off . Believe I will soak it in some Chemtool B-12 over night Plus i need to get a filter before the carb fuel intel There was not one installed when i took the carb apart.
    Again thanks for the help
  • Kelly
    Kelly Apr 17, 2011
    Installing a fuel filter will stop the debris from cloggin your jet orifices. That is a must on an older tractor. Just to many sources for rust to do the clogging of things as they age. If you do not install a filter... this symptom will repeat often.
    If you would please.... rate the post now as you see fit. I was just glad to have been able to help.
    Take care,
    Kelly
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Why does my 8N Ford tractor die at about half throttle?
Sounds like it might be starved for either air or fuel. Have you made sure there is full gas flow from the tank to the carb? Also recheck the needle valve regulating gas flow into the carb. May be that a speck of trash is partially plugging that flow to carb. Should have in-line fuel filter (add on) in addition to the bowl 'filter
Mar 30, 2014 | Ford 8N Tractor
Gas not getting to carburetor on riding 16 hp lawn tractor
Most of these engines have fuel tanks with a small valve (often plastic) that open / close the fuel supply from the tank to the tubing that connects to the carb. The in-line type looks like this:
Some of these devices are part of the tank - regardless of the exact physical location, it will be somewhere between the carb and fuel tank. The handle should be aligned with the connection tubes to be open or across to be closed. May sure your's is open.
The other items that could be the problem is the fuel filter. These are also most often found as an in-line device and have different appearances. Generally, the only devices between the tank and carb are the shut off valve and fuel filter, so if its not one it is likely the other. Here's a picture of a couple typical fuel filters:
Note that most fuel filters are directional. Point the arrow on the case in the direction of the fuel flow - which is toward the carb.
If you remove a hose from these components, some fuel will spill. If the shut off valve is open, the tank will begin to drain too, until you close the valve. You can test for fuel availability to the carb by removing the fuel supply tube from the carb. If fuel begins to flow, there is no obstruction with the valve, filter or tubing.
If these fixes don't solve the problem, make sure the opening in the tank isn't clogged with debris and that the carb is clean (use a cleaning spray designed for carb cleaning)
I hope this helps & good luck!
Feb 06, 2013 | Garden
I'm rebuilding a ford 2N Governor. I see that the Drive shaft and ball fin or divider are separate. Should the divider be a tight fit on shaft to rotate the four balls during operation?
Yes. The balls move outward by centrifugal force. The faster the governor shaft rotates the farther out the balls move until it actuates to limit the fuel flow.
If really helpful, please rate.
Jul 13, 2011 | Ford 2n, 9n, 8n Tractor Left Taillight...
Can't get fuel to the plugs on my 9n ford
You have an updraft carb. which means good valve seating is important, otherwise aleaking intake valve will force fuel out of the carb.
Sep 19, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Runs with choke on but pitters out when i take choke off
Will it idle ok or is it not running at higher rpm?
First......take the gas line off at the carb and check for a good flow of fuel to the carb.No flow means ...check for blockage at the tank glass bowl filter....take the glass off and open the gas valve....any flow?......if not unscrew the glass bowl assembly and clean that filter screen......you will need your wife to hold her finger over the hole on the tank while you check that screen,get a snack and a drink.
If flow was good to the carb .....try turning the main jet out a few turns (the bigger of the two jet adjusters) (they usually have a place for a flat screwdriver slot in them)The small one is idle mixture.
If that does not do it......there is a small screen filter where the fuel line goes into the carb....unscrew that and check for dirt.
TIP.DO NOT BLOW AIR THROUGH THE JETS THE CLEAR THEM ON THIS CARB.You will compress the float.
If the above didn't do it......
This carb is VERY simple to work on.
Get a carb kit then dissasemble it and clean every hole and passage you can find....install the kit and It will run well for years.
Aug 13, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
My 9N is having trouble starting. It turns over fine but seems to be flooding. When it finally sputters to a start, it takes a while to run smooth. Also the idle seems to be fast and there is no change in...
Shut off fuel to carburetor, drain carburetor. Open fuel and count to three then shut off fuel. Crank engine then pull choke for 1 second then push in. If engine starts open fuel valve at tank. Also try lowering float level in carburetor. Good luck.
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
I have a 2n ford tractor. Starts great but will
Hello
Have you Checked the Point Set Gap?
If the Point Set Gap is Not Set Correctly or the Contacts are Burnt, then you will have this Problem.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Garden Logo
218 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
