Question about Vivitar DVR410BLACK Pocket Video Camcorder
My vivitar dvr 410 won't turn on. When I plug it in to the computer it says MSDC and i even took out the memory card and fliped down its switch...the same thing happened.....
    Problem Solver:
  • 17 Answers
MSDC is displayed on the camera's LCD screen when connected to your PC because the PC recognizes the camera as a "mass storage device". make sure you installed the software to your PC before you connect the camera.
Posted on May 16, 2011
Msdc blue screen on my camcorder
Try to go thru menu and do a factory reset?
Mar 10, 2014 | Vivitar ViviCam 8025 Digital Camera
Vivitar vivicam T135 3D
The MSDC merely indicates that the camera acknowledges the connection to the computer. You can control the download process from the computer. That's about the only thing you can do with the camera while it's connected. If you want to do anything with the camera, you must disconnect it first.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Aug 11, 2013 | Cameras
Vivitar camera isnt reading sd card
What type and size memory card? Is it formatted?
Dec 22, 2012 | Vivitar Dvr-410 - Camcorder - 1.3 Mpix -...
WHEN i TRY TO DOWN LOAD PICTURES THE CAMERA THE PICTURES GOES OFF AND THE CAMERA SAYS MSDC
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Apr 02, 2011 | Vivitar ViviCam 3915 Digital Camera
My new vivitar dvr 410 wont take pictures - the screen says "card protect" is this camera broken or is there a secret to using it... Thank you! B
Take out the memory card and find a switch on it. You may have accidentally set the switch on the memory card to enable write protection. Switch it off and reinsert the card into the device, and it should be able to work now.
Mar 05, 2011 | Vivitar DVR410BLACK Pocket Video Camcorder
Do i need a sd card to operate my vivitar 410
Yes you do. The Vivitar DVR 410 requires a standard SD memory card (up to 16GB) to record images or video. The 410 is NOT designed to accept SDHC memory cards so make sure you purchase the proper type.
Jan 05, 2011 | Vivitar DVR410BLACK Pocket Video Camcorder
My vivitar 410 is saying the memory is full but it has a brand new sd card???
Hi
There are two Vivitar DVR-410 models. A model released in the early 2000's and a newer version released in 2010.
If you have the the earlier DVR-410 model then it will probably only use low capacity SD cards - e.g. 512Mb or lower. if you are trying to use a higher capacity card on this model it may well show that it is full.
If you have the modern 2010 version of the DVR-410 then it can uses SD cards upto 2Gb and SDHC cards upto 16Gb
You should also check the card you are trying to use is formatted, and the lock switch is not set.
Hope this helps
David
Dec 29, 2010 | Vivitar Cameras
Everytime i plug my camera into the computer msdc pops up on my camera i tired to download the fix thing but it doesnt work either
The MSDC is merely the camera's way of acknowledging the connection to the computer. You control the download from the computer, not the camera.
Of course, you might want to consider NOT connecting the camera to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Aug 20, 2010 | Vivitar ViviCam 8025 Digital Camera
Memory Card
Make sure your battery is inserted in the proper direction (it will fit even if upside down).
Dec 25, 2009 | Vivitar ViviCam 8025 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Vivitar DVR410BLACK Pocket Video Camcorder Logo
681 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Luis Soria
Luis Soria
Level 1 Expert
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
