Question about Troy Garden
Need to replace starter rope on troy-bilt TB490BC, looks like clutch neeeds to come off shaft. is this correct ? and how to remove it. Thank you
  • Roy Cagle
    Roy Cagle Apr 08, 2011
    I've disassembled and repaired numerous 2 stroke Troy Bilt type machines, but not this model. It looks like the clutch will need to be removed. I can give you instructions for the 2 stroke model. Your biggest challenge will be to lock up the engine so you can turn the clutch off the end of the crankshaft. Hope this helps Post back if you feel the need to.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Again, post back, we'll see your comment and be happy to help!
5 Suggested Answers
  • 28 Answers
SOURCE: troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Posted on Aug 06, 2009
  • 202 Answers
SOURCE: How do I fix/replace the starter rope on a TB20CS
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Posted on Aug 09, 2010
tunde007
  • 2382 Answers
SOURCE: How do I replace the
Hi, you must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Posted on Sep 06, 2010
rycgl
  • 1545 Answers
SOURCE: starter rope replacement instructions for a model
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed
Posted on May 07, 2011
Troy bilt tiller th-1002 Has no spark.
Couple of things. First thing I would do is take the wires off the back of the kill switch and the check for spark, I've seen a few bad switch's. If you still have no spark then the coil is next, getting to it can not be to easy you'll have to remove the shaft then the front of the engine housing next remove the clutch cover. What I do to remove these clutch cover is remove the spark plug and take a piece of 5/16 rope about 6 in. long and put about 3 in. of it down the spark plug hole pull the starter cord slowly till the piston come up to the rope and stops the engine from tuning. This way you can take a T-20 star driver and reach inside of the hole on the clutch cover and loosen the screw that holds the clutch cover on. (Leave the rope in the spark plug hole) Under the cover you'll find the clutch it's self, it's going to have the word off and a arrow stamped it. I take a brass drift and hammer to unscrew it but have used channel locks. Then remove the 4 screws holding the housing to the engine under all this you'll find the flywheel and coil. Some time you'll find the magnet's on the flywheel rusty and need to be cleaned with sand paper, or the pickups on the coil that reads the magnets dirty. But the only way to check and see if either of these helped you have to put everything back together and try it. So after doing all this work to get there its usually better to replace the coil with a known good one and then put it back together. Good Luck to ya.
Oct 13, 2014 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Rope will not recoil complety
Replacing a pull cord is not easy. After you remove the shaft, then the drum cover, you are left with the drum and clutch. There is a screw in the center of the drum which has to come off. Then there is a the clutch which if not removed correctly will come apart on you. Only after both parts are remove can you get to the pull cord.
Oct 19, 2013 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
Sep 25, 2013 | Troy-Bilt Garden
How do I replace the pull cord on the Troy Built Mower model # 12AI867Q011 serial # 1E098KC0419
You have two options. look up your models starter assy. at a dealer like www.arcolawn.com and replace it as a whole or purchase the rope remove the starter, charge the spring by twisting it all the way tight, back it off one turn and install the new rope. Tie your knots and reinstall the starter.
Thank you
Joe
Oct 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do I replace the starter pull rope on TB70SS?
You must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt trimmer TB 490 BC
Turn the bump knob clockwise to loosen on my tb490bc.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt string trimmer starter rope
Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Starter rope on Troybilt TB575SS
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Oct 04, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
66 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
