Question about Polycom Lands Phones
I have a Polycom soundstation 2 and it is not working, can not hear people on the speaker phone.
  • 682 Answers
Http://www.brennanit.com.au/UserGuides/User%20Guide%20-%20Polycom%20Soundstation2.pdf
Posted on Aug 06, 2008
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
Need a user Manual
here the most i can find
The SoundStation Premier and Soundstation Premier EX has been discontinued and is no longer available for purchase. Support for the product will be available until 02/21/2010.
http://www.polycom.com/global/documents/support/setup_maintenance/products/voice/soundstation_premier_user_guide.pdf
Mar 19, 2009 | Lands Phones
Usin for an internet conference
You need to buy a Computer Calling Kit from Polycom. That is essentially a cable with a 2.5mm connector to the Polycom Soundstation 2W on one end and two 3.5 mm connectors to the PC Sound card end (one to the Microphone port and the other to the Speakers port).
Mar 08, 2009 | Polycom SoundStation 2W (2200-07800-001)...
Opening Up A PolyCom Soundstation EX
you have to remove the rubber footings directly under the keypad of your polycom. . . It has 2 screws under those rubber footings.
Sep 22, 2008 | Polycom SoundStation
Polycom soundstation 2W
I went to Admn Setup to reboot the system from Please Wait.... & it doesn't work!! Best Solution posted on Sep 19, 2008 2%20stars.png
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Just had this problem with the 'please wait' - go into the admin setup and select Reboot Phone - it then works!
Jun 23, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Comcast Cable Modem with Polycom Soundstation Premier
Try adjusting the ringer volume, dial tone volume, and speaker volume. Make sure that the ringer type selection is not set to off. Also make sure that you are not bridging your call.
You can also use the Upgrade feature built into the phone to look for updates which may resolve your issue.
If this has only started happening recently, Restore the default settings and see if it resolves your issue.
Mar 20, 2008 | Polycom SoundStation
Adding person to a teleconference group
How can I add 3 other people on the conference call using a Polycom Soundstation?
Jan 08, 2008 | Polycom SoundStation
POLYCOM SOUNDSTATION 2W
I thought well I wonder what holding down other buttons would do to get rid of this cursed PLEASE WAIT issue.
I tried * and # together and hey presto it worked.
I did however have to go in and turn IP mode off.
Dec 07, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Lands Phones Logo
136 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
