Question about Panasonic Televison & Video
I have replaced the lamp (dlp lamp). How do i reset the light?
    Problem Solver:
  • 11 Answers
I believe there are different codes depending on model but try holding down pip button on your remote and the vol down on the sett simualtaneously on the tv set for about 15 sec a message will let you know if it has reset. if that doesnt work try the menu button on tv and the pip on the remote.
Posted on Apr 08, 2011
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
I have a 65737 Model Mitsubishi DLP TV. I changed out the DMD formatter Board and DLP Chip Yesterday and now the Lamp will not come on. It worked fine until I changed the Board because it had Vertic
Hello, make sure all the covers are on correctly, then recheck all the wiring connections, unplug each one and inspect them for a bent pin. Let me know....tks
Jan 03, 2015 | Mitsubishi WD65737 65" DLP TV
Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
This is the excerpt from the manual on how to reset the lamp life timer.
Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
Jan 12, 2011 | Optoma HD65 DLP Projector
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
My samsung dlp have sound but not picture. I
U put the cover back on,u might of acidently hit the reset protection switch to the lamp module.Check it over,becarefull after the switch back to it proper place.The lamp will light up and work.
May 03, 2010 | Televison & Video
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
The tv shuts down and an orange light flashes
if it's the lamp led that is orange, turn off the projector for a minute and try it again. if the lamp goes out and the orange led comes on again, replace the lamp and reset the lamp timer.
Jul 25, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
