Question about Dell Computers & Internet
On switch "on" getting "Beep"
    Scholar:
  • 85 Answers
It means the computer has encountered a critical error when booting up. One reason may be the power. If your power supply is rated 110V and you plugged it in to 220V, it could be one reason. Another is, you have a bad RAM. Turn off your computer and unplug it. Then try opening the computer case, remove the memory and clean it with a clean cloth, and then put it back firmly. If that doesn't work, do the same with your video card (if you have one). If that still doesn't work, you'll need your computer to be serviced.
Posted on Apr 08, 2011
Turn off beep on 8060 savin copier
See page 76 from the Operation Instruction Manual:
ftp://ftp.panasonic.com/printer/om/dp-8060-copy_en_om.pdf
"The Key Operator Password is required before any changes can be made"
Screen No. Modes Function Initial Setting
03/13 11 TCH Panel Beep Sound
Beep sounds when touching the panel.
? Off, Soft, Loud Soft
Jul 01, 2014 | Acer Aspire 5810T-8060 Notebook
My emachines desktop ET1161-07 is randomly playing a high-low beep
A virus check might not get all malware. Download Malwarebytes free and do a scan with that. Check the add-ons installed in you browsers and get rid of superfluous or strange ones. Use msconfig to check which programs are loaded at start up. Uncheck unnecessary or suspicious ones. Good luck.
Jun 17, 2012 | eMachines ET1161-07 Desktop PC
Sony Vaio LT35E 1 long beep and 2 short beep on power on. no display. need help
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
It seems that there is RAM issue because of which you are 1 long beep and 2 short beeps refers on your Sony Viao laptop in such case the basic thing is to replace your RAM and youn't be able to get the beep sound again or else you can also Rub the golden foil of your RAM with rubber and try to insert it again. Hope it works for you.
May 24, 2011 | Sony VAIO LT35E T8100 2.1G 3GB 640GB BDRRW...
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
I am having problem with my computer. Initially it started with a Beep everytime I use to boot the computer, it gave me a message after the beep that " Your password expires in 14 days do you want to...
hi nitind
  • It's not big problem
  • re-boot ur system
  • you r telling you r upgrade your pc,so it supports windows7 too
  • put a new copy of windows 7 original
  • if not means disable the windows update after installing ...
  • before the problem may arise due to corruption of files or password is not a valid one ..
  • so put a fresh copy of windows in which drive already you have os...
  • other drive data must be safe...
  • keep antivirus active this must be helpful for your pc ...
Dec 25, 2010 | Computers & Internet
The pc is powered but not booting up
you need to describe it more clearly. Anyway, first thing is to listen to the beep sound (google: bios beep code) to identify the initial problem
Aug 27, 2010 | Computers & Internet
Beep sound while booting?
is likely normal.
many computers beep when what is called the 'bios' first starts up. Older computers used to even tick as they did an initial memory check.
Nov 30, 2009 | Acer Aspire 5315 Notebook
I want to disconnect the beep sound when I press record
From the manual:
"When [BEEP SOUND] on the [INITIAL] Sub-Menu on
the [TAPE RECORDING MENU] is set to [ON],
confirmation/alarm beeps are issued as follows.
1 Beep
• When you start recording
• When you switch the [OFF/ON] Switch from [OFF] to
[ON]
2 Beeps
• When you pause recording
2 Beeps 4 times
• If you perform a wrong operation before or during
recording."
Aug 16, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Computers & Internet Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
