Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
How do I enter date,time, caller id?
I cannot entre date, time and calller ID on the face of my phones
  • letatowle Aug 18, 2008
    Need to add 1 + area code to return caller id number easily
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Nov 30, 2012
5 Suggested Answers
SOURCE:
  • 136 Answers
SOURCE: caller id
you must set the base time as well as the handset time
enter global setup menu then
time and date submenu
then vol. up / down for day
then hour
then minute pressind save each time
Posted on Mar 30, 2008
SOURCE: Caller ID
caller id wont work and incoming calls wont display
Posted on Jul 06, 2008
SOURCE: Base Shuts Off
You can go to Uniden.com to see the manual for these phones.
Posted on Jul 10, 2008
seanpwright
  • 2030 Answers
SOURCE: caller id doesn't work on all four phones
Its one of two things.
1) the phone company needs to correct the caller id signal sent to your phone, or
2) the base unit is going bad and cannot proccess the caller ID signals.
Call the phone company and ask them to check your caller id coding first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on May 16, 2010
No Data Sent keeps appearing on Caller ID box and date and time does not change , can you help?
Make sure your "Date" and "time" are set on the phone in question and if it still doesn't work make sure your telephone provider has Caller ID activated if that is the only caller ID phone.
Aug 26, 2014 | Lands Phones
Southern Telecom Large Display Caller ID CID 50LD manual
Set Date and time manually if desired. 1. Press and hold the [dial] button until the display show "SET left OR right ". 2. Use the up or down buttons and select "DATE/TIME" andpress the [dial] button to enter.3. Use the up or down buttons to set the hour, minute, AM/PM,month, and day.4. Press the [dial] button to confirm your selections
Nov 28, 2013 | Southern Telecom Large Display Caller ID...
After installing new batteries I have lost my time and date on the window display
The date and time is supplied with the caller ID information from your phone service provider. When you get a call, the date and time will be set. (If you don't have caller ID, there's no way to set the date and time otherwise. I've always wondered who came up with such a silly design.)
Jan 30, 2011 | GE 29385GE1 Corded Phone
How ddo I change the date?
The time and date will update automatically when you receive a call as long as you receive caller id from the telephone service provider. Current time and date are part of the Caller ID data stream. Once the time is received the Fanstel unit will keep time from there and it will be updated every time you get a new call.
May 09, 2010 | Fanstel Caller ID Box Phone
I. calller id says no data
u will do reset ur ph from setting option and restart ur ph.then problem will solved
Apr 16, 2010 | GE 25932 Cordless Phone
Doro 80
If you get caller ID, it will automatically set the caller id on an incoming call Otherwise: Press the OK/Menu button scroll to DATE/TIME using the up and down arrows, then press OK Enter Month (01-12) press OK Enter Day (01-31) press OK Enter hour (01-12) press OK Enter Minutes (01-59) press OK scroll to AM/PM using the up and down arrows press OK to save settings
Jun 08, 2009 | Lands Phones
Caller ID date and time doesn't show up on cordless phones
Here is a link to the manual for the 756 series of Uniden phones.
http://www.uniden.com/pdf/DCT756om.pdf
You should just have to set the caller ID time and date. Hope this helps.
Mar 29, 2009 | Uniden DCT756-3 Phone
Time and Date wrong on caller ID
I would check with your service provider. It maybe just a programming error in the switch from there.
Jan 31, 2008 | Uniden TRU8885-2 Cordless Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
94 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
