Question about Clarion Car Audio & Video
Connected power to the db176mp cd player it turns on and i connected the wiring to the speakers but no sound
LVT7857
  • 116 Answers
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
zenglish87
  • 5 Answers
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
  • 10 Answers
SOURCE: wiring colours for the sound system MAZDA PREMACY 200
well if you have not cut the wires you can go to wal-mart or autozone ask for a after market wire harnis just tell them the make and model . but if you have cut them then get a light tester
Posted on Apr 10, 2009
SOURCE: MY RADIO AND CD PLAYER DISPLAYS SHOWS TO BE
Some high-power players have an internal fuse in line with the speakers so that an external short will not blow the output transistors. Have someone skilled look for this.
Also, check that your speakers are not wired backwards; some speakers will connect one side of the voice coil to ground. If you connect the hot side of your CD player to the ground side of the speaker, you kill the sound.
Posted on May 20, 2009
messstat
  • 365 Answers
SOURCE: I have RCA preout connections at the back of my
If I understand you right, you should be running a single wire to the amp in addition to the RCA's
Posted on Jun 14, 2009
I have fitted a after market cd player in my dodge nitro 2007 it power up ok but no sound i did buy the harness but it don't have the blue amp rem wire on it help do i have to bypass the amp or can any...
It may not need to be connected anywhere, those are often power from the stereo to the amp, so the amp turns on with the stereo. Also, is it 2 speakers, 4 speakers, 6 speakers?
Oct 04, 2013 | Dodge Nitro Cars & Trucks
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
Xtreme Sound WMS336 CD PLAYER NO SOUND CAN YOU HELP ME THANKS
im install cd player for my car, but not sound came out at all. removed it out, try check for connection, but everything was fine. then i did try play around for speaker 's wire speaker. i saw blue ( power ant) just connect to nowhere. then used blue wire to connect for output speaker, then sound show up. but rerarely to heard. cuz sond was too low. even volume was max. i thought maybe they need for more ground to run out put, or sound chip 40 legs is gone. ( need to replace for it?
Feb 13, 2011 | Xtreme Sound WMS336 CD Player
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me mail@srands.co.uk
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me mail@srands.co.uk
Dec 01, 2009 | Car Audio & Video
I just bought some speakers and a receiver, cd player no instructions, how do i connect it myself
- Use a cinch- cable (red&white) to connect the cd player to the input (often called CD or AUX) of the receiver
- Use standard speaker cable (two copper wires per wire) to connect each speaker to one speaker-output on the receiver
- Plug in the power cables
- Select the right input (or source) on the receiver
- Voila! Press play on the cd player and sound should come out!
Oct 08, 2009 | Audio Players & Recorders
No sound output - pioneer DEHP6700MP
Sounds like a grounded speaker, disconnect each speaker and see if the sound comes back on through the remaining speakers connected. Its sounds like it is just in protection mode from a chssis ground. I hope this helps!
May 30, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
MY RADIO AND CD PLAYER DISPLAYS SHOWS TO BE WORKING, HOWEVER THERE IS NO SOUND. THE FUSE BOX FUSES ARE ALL GOOD. THE SPEAKER WIRES ARE ALL CONNECTED. WHAT COULD POSSIBLY BE THE PROBLEM.
Mar 07, 2009 | 2002 Suzuki XL-7
Cd player plays, but no sound comes out of speakers.
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Larry T
Winona Lake, IN
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
I replaced the cd player in my accord, the one before worked when i took it out, the radio i put in works as well tested it with hot and ground wires and a speaker to every terminal before i hooked it up...
On many cars there is an exterior amp that the sound goes through before it is sent to the speakers. If the remote turn on wire isnt connected after you take your previous cd player out then the amp wont know when to turn on and therefore no sound will come from your speakers although your cd player is doing its job.
Jul 20, 2008 | 2004 Honda Accord
Car Audio & Video Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
