Question about MSI L1350D-1672US Netbook
Tried to install 2gb ram in open slot and got blank screen. took it out and it started right up. why is it not taking the new ram? i upgraded to win 7 home premium, because starter max is 2 gb? didnt help. i cant figure it out.
  • 59 Answers
Make sure the new ram was properly seated. If the ram is not all the way in it can cause various issues and even burn out your motherboard.
Posted on Apr 08, 2011
Testimonial: "could have been right, but was not a fix for my issue."
  • 3 more comments
  • brepynso Apr 08, 2011
    thanks, that would have been so nice if it was that easy. but.... im sure ram was properly seated. when i put ram in and power on, i just get a blank screen. the fans and lights come on, but nothing else happenes. any other ideas?
  • jonathan mcneilan Apr 08, 2011
    I was able to find someone else who solved the issue with the method below. Hope this helps.
    Clean the original RAM edge connectors with a pencil eraser and pop it in and out a few times to clear oxide off the actual sockets(s). You often get this sort of problem when you disturb RAM.
    thank you. i dont think that is the issue either, all metal contact points are clean.
    ive taken it out and put it back in at least 6 times.
    the computer has 1 gb pre installed and not removable, with an open slot for ddr3. new 2 gb ddr3 fits but then no respone when powered exept lights and fans, no screen.
    ive read things about bios updates but my bios are pretty new 2010...
    hardware compatibility??
    msi l1350d
    any info or insight about the problem is greatly appreciated.
    I found this site that has the specs for your motherboards ram. Hope you can find something.http://www.crucial.com/eu/upgrade/compat...
  • brepynso Apr 11, 2011
    ok i was offline for a couple day beause i accidently disconnected my keyboard when i took the case apart, and the keyboard shortcut would not work, on usb keyboard, to enable wireless adapter and NOTHING in device manager or ANYWHERE was even detecting adapter. but now.... all that is fixed. and i have had no progress in getting computer to start with additional ram installed. im going to try 1 gb instaed of 2gb in slot 2 and see what happens. thanks for your help and ill let you know what happens.
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
Aug 03, 2017 | Fujitsu LifeBook V700 Notebook 15.4...
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Laptop screen dont like keyboard slot ram
The NX6310 laptop supports up to 4 Gb of RAM either 533 or 667 MHz DDR SDRAM.
When memory upgrades don't work, the problem could be incapable memory between RAM modules.
Try to use RAM from the same manufacturer, especially the manufacturer of the working RAM.
Use RAM that have the same speed specification.
Jan 21, 2009 | HP Compaq nx6310 Notebook
Tried to upgrade RAM now computer won't boot up
check ther is 4 ram bank and if then fix ram after left 1 bank.then check .
there is also check frequency same of both ram.
Jan 10, 2009 | Computers & Internet
Trying to upgrade RAM - won't boot after new RAM installed
Install the RAM on memory slot and Switch on your system and go to BIOS settings. There you can check whether your RAM is working properly or not. If it shows no memory installed then the RAM Chip may be damaged.
Jan 08, 2009 | E-Machines T6520 PC Desktop
Acer Aspire 5584WXMI Upgraded Ram
All ram is not created equal.
You should check on the Laptops manufacturer website support pages. They should have a list of know ram manufacturers that have been tested with your laptop.
Check in the manual to see if the ram may have to be installed in pairs.
Also, be sure the new ram is seated properly in the slot.
The ram may not be fully compatible with your laptop.
Dec 16, 2008 | Acer Aspire 5100 Notebook
How to install new ram into the 2840
Unplug the machine. On the right side of the machine you will find a cover. Remove the cover and you will find 1 open slot. The machine can take a total of 224MB (96 is built into the machine) leaving 128 available. The memory type is 100pin, 133MHz, SDRAM DIMM.
Simply click the memory into the blank slot and replace the cover.
Once completed, plug the machine back in and print a configuration page. The memory total should be at 224 once you have installed your 128MB.
Good Luck
Jul 24, 2008 | HP LaserJet 2840 All-In-One Printer
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
MSI L1350D-1672US Netbook Logo
396 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
