Nangongopya ba c rem? - Computers & Internet
  • 942 Answers
Hindi 100% ang pangongopya ni rem. Rememthat that REm or RAm e parang mirroring ng Operating System, it does copy coes pero hindi lahat ng files sa computer mo..
Posted on Apr 08, 2011
Where connect rem connection
rem goes to the back of the headunit to a cable (blue or blue/white) that should say, either rem out or power continuous (PO CON) and needs to connect to the amplifier where it sais rem power(12v)
hope this helps
...andy...
Jan 05, 2014 | Car Audio & Video
How many fuel pump relay fuses is their on a lincoln ls v6
There are no fuel pump "relay" fuses. There is a fuel pump fuse that protects the secondary (contact) side of the fuel pump relay, which supplies power to the Rear Electronic Module (REM), which in turn supplies power via a pulse-width generator to the fuel pump unit. The power for the primary side of the fuel pump relay is supplied by the REM and is protected by the fuse that protects the REM itself. The REM has 3 separate fused inputs and the manufacturer does not provide information to indicate which of these fuses provide the output power from the REM to the fuel pump relay.
If you are trying to diagnose your fuel pump circuits, it is necessary to use a scan tool that has vehicle-specific capabilities and can access fault codes and live data from both the the Powertrain Control Module (PCM) and the REM. Two-way communications and actuator testing is also necessary for certain tests involved in verifying the fuel pump circuits.
The easiest way to verify whether the entire system is working or not would be to check for the proper voltage (over 12.5 volts) at the Fuel Pump Module (FPM) electrical connector. If the correct voltage is present at the FPM connectors, then the fuel pump relay, the REM, and all related fuses are good. However, to do this, once again, it requires a scan tool as described above so that the fuel pump can be commanded ON through the computer system functional tests.
Nov 22, 2011 | 2002 Lincoln LS
Draw a flowchart to enter a number from 1 to 7 and display the corresponding day of the week
1 rem zero out all variables housekeeping
10 let a=0
15 clear $today
16 rem get input
17 input a
19 rem choose corresponding day of the week
20 rem case structure
25 if a=1 then $today="sunday"
30 if a=2 then $today="tuesday"
rem ect til saturday
rem use data created
40 print "today is";$today
Apr 27, 2011 | Computers & Internet
What is rem
rem means remote on the amplifier which means your amp will turn on when ur radio turns on the remote wire goes from the back of the stereo usually always a blue wire to the rem on the input to the amp
May 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Can"t change LCD display panel from REM status--
turn to rem off then you can change temp if not bad display board
Dec 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to play .rem music
Mr Dinesh
REM file extension appears when media files are saved to device memory and are not removed when the media file is transferred to a computer.
You cant change this..after transferring the media file to the computer, rename the file to remove the .rem extension.
I hope this info help full for you
Nov 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
1999 Ford Windstar Rear Light/REM issue ??
How would i be able to get a manual for my 1999 ford windstar van?
May 21, 2009 | 1999 Ford Windstar
No break lights, need location of fuse for the break lights 2000 ford windstar
please rate if this helps.
Exterior Lighting The exterior lighting outputs are zone controlled by the front electronic module (FEM) and rear electronic module (REM) in respect to the front exterior lights being controlled by the FEM and the rear exterior lights being controlled by the REM. An additional function of the lighting system is a lamp outage function which provides the indication to the driver if certain exterior bulbs are not functioning. With a bulb inoperative, the FEM or REM will send a message to the instrument cluster and message center (if equipped) which will in turn indicate to the driver the lamp is inoperative with a lamp out indicator (with the message center a message will be displayed). To provide complete input and output functionality, each exterior lamp feature will be described individually. All exterior lighting is powered by the switched system power (SSP) feature (refer to Switched System Power[SSP]). A failure of all or any of the SSP features will cause inoperative exterior lighting. When diagnosing exterior lighting, it is essential to determine if all related symptoms and DTCs are controlled by the SSP feature.
Stoplamps Brake lighting is controlled by the REM. The brake pedal position (BPP) switch is hardwired to the REM. When the brake pedal is depressed, the BPP switch will input information to the REM. Then, the REM will process the information and output to the left, right, and high mounted stoplamps. Only the left and right stoplamps will provide lamp outage indication.
The vehicle's electronic functions are divided into zones. The FEM controls the front portion of the vehicle and the REM controls the rear portion of the vehicle. These systems rely heavily on the SCP communication network in order to transmit and receive signals. As a technician it is very important to understand:
  • where the input (command) originates from
  • All information (messages) necessary in order for a feature to operate
  • which module(s) receive(s) the input or command message
  • does the module which received the input (message), control the output of the feature, or does it output a message over the SCP communication network to another module
  • which module controls the output of the feature
Switched System Power (SSP)
The SSP is invoked by both the FEM and REM. This function removes power from relays that provide power to the exterior lamps, interior lamps, and power door locks. This is only accomplished when both the FEM and the REM are in sleep mode. The sleep function of the FEM and REM places the modules in sleep mode when the ignition switch is in the OFF position, and no wake up (inputs) signals occur for 30 minutes. The module will not sleep if the parking lamps or the hazard lamps are active. The following relays are controlled by the SSP function: SSP1, SSP2, SSP3, and SSP4. When either the FEM or REM are not in sleep mode, all SSP relays will be energized. When energized, each relay will supply power to multiple features/functions. For additional information, go to the SSP Index for diagnosis and testing of SSP related issues. Refer to Headlamps .
Inspection and Verification
  1. Verify the customer concern by operating the stoplamps.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Damaged REM
  • Blown central junction box (CJB) Fuses:
    • 13 (15A)
    • 7 (15A)
    • 12 (20A)
    • 11 (10A)
  • Damaged wiring harness
  • Loose or corroded connections
  • Damaged BPP switch
Apr 24, 2009 | 2000 Ford Windstar
Powers isnt turning on but everythings hooked up?
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Oct 03, 2008 | Car Audio & Video
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
