Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Error on my printer says printhead carriage jam. open printer acess door. clear any obstruction check installation of printhead and ink cartridges close door press ok to continue did all of that it did not fix it what do i do?
  • Anonymous Mar 27, 2014
    getting an error message saying print carriage jammed,. remove any obstruction. There is nothing in the way of the carriage.
    Guru:
  • 352 Answers
Remove the cartridges and Print head if possible, unplug the printer for 10 mins, switch on and Re-install the head and cartridges.
Hope this helps GM
Posted on Apr 08, 2011
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
Kodak com go aiosupport
You do not say what model of printer you have.
When you open the access door, the print heads normally move into the centre. Does yours?
If not, that is the problem
The only suggestion I can make then is to get a cotton bud, and a thin oil [like machine oil or cycle oil]
Just moisten the bud [not dripping wet] and slide it along the printer rails. Problem is you cannot reach the rails where the print head is stuck! Do as much as you can and leave for an hour or two.
Mar 08, 2014 | Office Equipment & Supplies
We have a ESP 7250 the print head carriage shows jammed but I can't get the ink cases to move. So I can check it
To resolve this error: Open the printer access door. Disconnect the power adapter from the printer. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely. Remove the printhead and ink cartridges. Reinstall the printhead and ink cartridges, making sure each clicks into place. Connect the power adapter to the printer. Turn the printer on. Close the printer access door Hope this helps resolve your problem
Jan 04, 2013 | Office Equipment & Supplies
Keep getting paper jam fault 3618
Hi!
If the error comes up during the initial setup of the printer:
  • Select All-in-One Printers.
  • Double-click the Setup Guide for your printer.
  1. Open the printer access door.
  2. Remove all:
    • orange shipping tape
    • foam pieces
  3. Follow the steps in the Setup Guide to insure that you have properly installed the printhead and ink cartridges.
  4. Close the printer access door.
  5. Press OK to clear the error.
  6. Make a print.
OR
Check the printhead carriage area:
Debris and Obstructions:
  1. Remove any paper, tape or other obstructions from the printhead carriage area.
  2. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
Ink Cartridges:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
    NOTE: If the printhead does not move to the center position, press Home, then Maintenance on your printer. Check if the Install Ink Cartridge option is available. If so, select Install Ink Cartridges, press OK, and follow the instructions. Otherwise do the following:
    1. If an error is displayed on your printer control panel or the status monitor on your computer, press Cancel to clear the error.
    2. Go to KODAK All-in-One Printer Downloads and Drivers, select your printer from the All-in-One Printers pull-down list, and download and install the latest firmware version for your printer. Follow the on-screen instructions.
    3. After you upgrade the firmware, press Home on the printer control panel.
    4. Select Maintenance, then press OK.
    5. Select Install Ink Cartridges, then press OK.
    6. Follow the instructions on the control panel LCD.
    7. Go to the next step.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Press OK to clear the error.
  8. Make a print.
Hope this helps.
Apr 19, 2011 | Kodak ESP5250 All-In-One InkJet Printer
My kodak esp 7200 series printer keeps saying theres a printhead carriage jam. ive done everything its asked and there not shouldnt be a problem but it keeps stalling up.
Open the printer access door and clear any obstructions. Check that the printhead and ink cartridges are installedcorrectly. (The printhead and ink cartridges are installed correctly when youhear them click into place.)
Apr 17, 2011 | Kodak ESP 5 Printer
Error message! I just got a Kodak 5210 printer and it keeps saying "printhead carriage jam. open printer access door. clear any obstruction. check installation of printhead and ink cartilages. close...
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Computers & Internet
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Paper jam press ok to fix-then I get error code 3820
  2. Disconnect the power adapter from the printer.
  3. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely.
  4. Remove the printhead and ink cartridges.
  5. Reinstall the printhead and ink cartridges, making sure each clicks into place.
  7. Turn the printer on, if necessary.
  8. Close the printer access door.
If the error continues, contact Kodak.
Sep 24, 2010 | Kodak ESP 5 Printer
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
122 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
