Hi,what area will a1.5 hp. air conditioner cool.thankyou,terry jenner
    President:
  • 1,654 Answers
The horspower rating does not indicate cooling area, this is usually done in BTU's and therms and tons. What is the rating for these on your air conditioner.
Here is a link to the consumer guide on sizing an air conditioner. If you find this helpful I would appreciate a vote on the thumbs up for the free information. Thanks.
www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing..
Posted on Apr 08, 2011
Our reverse cycle airconditioner is not cooling in two of our bedrooms, but the rest of the house seems to be cooling alright, but I am sorry the airconditioner is approximately 6-7 years old and we have...
Hi, I assume it is ducted, it could be either a flapper door is closed to shut off an area from receiving air, or there is a blockage in the duct (less likely). Also if there is more than one duct attached to the air conditioner then you'll have to check if air is entering all ducts (you may have a problem with the unit).
Nov 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Air Conditoner not cooling entire room
I would guess by the question you posted that at one point this air conditioner DID cool the entire room. If that is in fact the case then chances are you have either 1. A dirty air filter, which can be found underneath the front grill of the unit, or 2. A dirty condenser coil, the coil found on the back of the unit, that is outdoors while the air conditioner is in the window. If this coil gets clogged up, then the proper heat transfer will not take place, and you will not get proper cooling. Hope this helps.
May 07, 2010 | GE AGF05LA Air Conditioner
My Ac do not cool enouhg, even it doesnt cool anything, i have my windows close and there is no equipment that produce heat!
Hi Cafe,
Ensure that the the discharge (hot air) is properly routed outside. Take temperature readings of the intake air (room air entering the unit) and the outtake air (cold air coming out of the unit). If the temperature difference is approx 18 to 22 degF, you might need more capacity. I believe your unit is 8,000 BTU. This is considered very small capacity. Not knowing what your situation is, it could be the right size. Below is a link to a site that will allow you to input information regarding the area you are trying to cool. It will calculate the BTU's needed to cool the area.
http://www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing-worksheet/index.htm
Let us know if this helps. Good Luck!
Feb 16, 2010 | Midea MPM-08CR-BB4 Portable Air...
Air not cold...model MSH-18NV no operating manual for remote . Not sure how to set to cool air when remote reads "I feel..." choices are cool dry or warm but when set on cool 20degrees, luke-warm air blows...
Hi FixYa team. After about 2 hours on the internet I managed to find a PDF file of the operating manual for my air con.
Thankyou for your prompt response. I'll be using your services again!
Jan 11, 2010 | Mitsubishi Heating & Cooling
My unit is not cooling.
This may sound idiotic but is the control set to COOL or snowflake symbol? Also set the temperature as low as it can go 16 degress or 18 if thats what your unit can go to. If the unit does not cool now, try cleaning the filters. If it does not cool after this, and the fiilters are cleans and the temp is as low as it goes, there may be a refrigerant leak and the system will need to be serviced. Hope all goes well.
I take the time to answer your question, so please rate me
Thankyou
Mat
Aug 28, 2009 | EMI WHP 09 Air Conditioner
When the control is set on air conditioning, it has recently started to dehumidify also on that setting. What to do? The unit is 5 years old.
I'm sorry is the unit set on COOL (snowflake) or DRY (raindrop) All air conditioner will dehumidify when in cooling mode. That is just the dynamics of air conditioning. The air should still be cool depending on your settings. if the air is not cool and you have confirmed that it is in cooling mode, check that the filters are clean and if they are have the system serviced.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi I have a Fujitsu Split system. As of recently it has started to mysteriously started to flick over from heating to cooling on its own. It is a 2.5KW unit and heats rather well. ALl of a sudden you hear...
Yes i can! The mode of operation (MASTER CONTROL)has been set to AUTO instead of HEAT. Easy mistake and very simple to fix. Press the MASTER CONTROL button until HEAT is display on the LCD.
I hope that this helps
I take the time to answer you questions so please rate me
Thankyou
Mat
Jul 13, 2009 | Fujitsu 18R1 Air Conditioner
Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 02, 2008 | Fujitsu 18C1 Air Conditioner
Logitech software
Hai, Jenner
Try connect the webcam to your computer, it wll detect the device, note down the device name it display towards the right bottom of your screen.
Then with this device name, brows google and enter device name + 'driver' in the search field click the search button.
U will be provided with numerous sites where from u can down load the driver for ur device.
good luck
vrabby@yahoo.com
Jun 15, 2008 | Logitech Computers & Internet
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
