Question about Panasonic PT-52LCX66 Projection Television
Panasonic Model PT-52LCX66. I just replaced the lamp in my tv and now two weeks later it won't turn on at all. The green light comes on and flashes. Then it just goes off. The screen never comes up. Can u please help?
SOURCE: panasonic pt-50lc13 shutting off
The Lamp is burnt out, Replace.
Posted on Dec 26, 2007
SOURCE: PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Posted on May 02, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
  • 15 Answers
SOURCE: panasonic pt 52lcx66 won't turn on
Sounds like the light engine. Is this a DLP or LCD rear projection? Did you see any patches of color any time before the problem with the really dark screen. Please rate my answer and let me know what other questions, Tech Malick
Posted on Feb 23, 2009
  • 90 Answers
SOURCE: I have a panasonic Pt-50LCZ70 TV.
I would suggest replacing the Lamp
Posted on Jul 09, 2009
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
My 52" PANASONIC PT-52LCX35 does not come on after a power surge went off due to lightning. I press the Power Button to turn TV on, but green light just blinks a few times then stop without any sign of...
Remove the Lamp and look for a white fog inside. It is bad if it looks that way.
If thats not it, Call a good TV Tech to troubleshoot the problem. Lightning can do about anything to electronics.
Jul 29, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic pt 52lcx66 won't turn on
Jan 31, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-52LCX66 Projection Television Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
