Question about HP D1560 Deskjet Printer InkJet
My d1560 printer is not printing, all it is doing is blinking and no paper is jammed, what can i do to get a document printed
  • 41 Answers
It is ink cartridge problem. Change it with genune one. problem will be solved.
Posted on Apr 08, 2011
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Hp desjet D1560 printer doesnt print it just blinks and even doesnt pull paper
Trying to turn off the printer by unplug the power supply. Plug it back in and turn it on.
Mar 02, 2011 | HP Deskjet D1560 InkJet Printer
My lexmark z22 has never been used, has a new ink cartridge installed, but will only print test pages -- not what i want to save. please help
First you need to connect the printer to your computer with the supplied printer cable including the power cable.
You need to install the printer driver on you computer.
You may need to setup the printer preferences, eg. paper size etc.
You printer is now ready to print your documents. When you have opened an document such as a word document, to print this document click on file - print
Nov 13, 2010 | HP D1560 Deskjet Printer InkJet
Printer states "out of paper" when there is a lot of paper in the carriage. Have pressed "Print" button 5 or 6 times, so.....how do I clear all the print requests, and reset the printer to recognise that...
Please perform the following steps and check if the issue is resolved.
1. Please try to Printer a Self Test-page.
>Please press the Power button to turn the product on.
>Hold the Power button down.
>Continue to hold the Power button, and then open and close the carriage access door four times.
>Release the Power button
>Now, try to print a self test page and check if that works.
If the self test page does not works/print a test page, clear the paper jam.
Also, clear the paper rollers and if this does not work, perform a power reset to resolve the issue.
You can refer the link below to get the complete information to perform all the steps mentioned above.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00861130&cc=us&lc=en&dlc=en&product=3374275
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02125514&cc=us&lc=en&dlc=en&product=3374275
Good Luck!!!!
Jul 02, 2010 | HP D1560 Deskjet Printer InkJet
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Carttridge is slamming against side of printer, light is flashing, no printing, no paper jam
I suspect the problem for both of you is either the blockage of the position sensing path (a slot in the carriage) or the plastic band that is imprinted with many vertical stripes and lets the printer know where it is and needs to go is not where it belongs.
Open the printer as you would to change cartridges and look carefully with a flashlight inside for a thin ~ 6mm (~1/4") plastic strip and insure that it is clean and stretched between both ends. One end is normally anchored to the chassis, the other attached to a spring suspension.
Nov 05, 2008 | HP D1560 Deskjet Printer InkJet
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
HP D1560 Deskjet Printer InkJet Logo
157 people viewed this question
Seeker5211
Seeker5211
