Question about Samsung Televison & Video
Alright, here are the details. Power set on, everything clicks and spins up normally, lamp fires and screen starts to light, faint white light. LAMP on power button flashes steady then goes out. After about 30 seconds, click, then lamp goes out. One funny thing is has the same symptoms whether the blue door switch is made or not. I have checked switch and applied pressure to the DNIe chip on the digital board. Any and all help is appreciated with this problem. Samsung model HLR4667W. BTW, already installed new lamp......
  • 5 more comments
  • snoogyme2 Apr 08, 2011
    Drew, thanks for the response but this is a DLP television. The part pictured does not exist within my television, or I have not seen it with the back open.
    Maybe something else?
    Thanks for the reply, i have unplugged the temp sensor and shorted the connector with the same results. Sensor reads closed with a meter when cold... the lamp does not stay on long enough to get real hot, but I have a new temp sensor being shipped since it is a $10 part.
    What I am failing to understand is why the sequence stays the same with the door interlock switch open or closed? Maybe the DMD doesn't look at the switch until it fires the lamp? but that would be silly, I would think that the switch being open would not let the lamp fire at all?
  • snoogyme2 Apr 09, 2011
    Drew,
    Came home from work and put a meter on the power supply that goes to the ballast, should read 300Vdc, I am only getting 160Vdc. Looks like this might be my problem. Lucky I know a guy that is good with power supply troubleshooting. The supply is going to him tomorrow.
    -Mike
    Power supply is good, I was using the wrong ground.
    Still trying to figure out why the DLP television is firing the lamp but does not display video, LAMP indicator on front flashes then goes out. After a couple of min. it shuts everything down and goes into standby. Any and all help is appreciated.
    Thanks eagle, I have eliminated the door switch and temp switch with jumpers, same result.
    Voltage @ the ballast plug is 320Vdc. Found and downloaded the Service manual, it points to DMD board, it recommends replacement : ( Going to verify signals to DMD from color wheel and lamp then I guess punt?
  • 4,889 Answers
I have seen a similar issue with exactly the same model. If the tv is not detecting that the door switch is closed then my money would be on the sub-detect board which checks the status of the lamp door. The part is very inexpensive(about 15$) and that should be the first thing to replace to see if the issue will be resolved.
Posted on Apr 09, 2011
  • 5 more comments
  • eagle338
    eagle338 Apr 09, 2011
    If its not the doorswitch then it has to be the DMB. This is because the sub-detect board relays the door switch status to the DMD which sends the lamp enable command and causes the lamp to light up to normal brightness. However you should first try measuring the input DCvoltage into the ballas and the output voltage at the pins from where the two thick wires go to the lamp and let me know. The voltages are usually around00V so set the range on the multimeter to 1000V
  • eagle338
    You got it. The ballast voltage is fine. I am sure that its the DMD now. It can't be anything else
  • Andrew P.
    Andrew P. Apr 14, 2011
    I agree with the DMD, as I've already had you check every switch on the tv. hahaha
  • snoogyme2 Apr 14, 2011
    Turned out to be the digital board, bought a broke TV off craigslist and used the digital board before trying the DMD, as the DMD need to be aligned when replaced. So far so good...
    I think the broke TV needs a color wheel, and well, a digital board too :O)
  • eagle338
    eagle338 Apr 14, 2011
    Glad to hear that.
  • Andrew P.
    Andrew P. Apr 15, 2011
    Good find on the broken tv. Obviously a lot of good parts to keep around for the future.
  • eagle338
    eagle338 Apr 15, 2011
    Yeah. Nothing better than that if you got it for a cheap price!
  • 325 Answers
Fault protection. How is your B+ voltage to the projection lamps?
I've often seen this problem and a SIMPLE B+ change out will fix the problem.
Here is what you are looking for to replace. This is right on the power supply and they tend to fail over time. Considering your tv is a projection, I highly recommend the replacement of the B+ flyback transformer.
Thank you, hope this helps :)
Posted on Apr 08, 2011
  • 3 more comments
  • Andrew P.
    Andrew P. Apr 08, 2011
    AH, DLP. Check right above the lamp housing. There will be a SMALL SMALL SMALL thermal fuse located here. These are rated at nearly 105 Celsius, however over time the bulb heats then cools, then heats, etc etc. The thermal fuse will fail causing this kind of behavior. You can "TEST" by bypassing the fuse by twisting the wires together.
    Try this, hope it works for you!
  • Andrew P.
    They can look like these!
    Good luck locating it and test again! :)
  • Andrew P.
    That is odd. Why not bypass the door switch (or order a new one to be safe). It seems there is some type of odd fault in it. Try to bypass it quickly and see the result.
  • Andrew P.
    Andrew P. Apr 09, 2011
    That amount of drop in voltage is directly linked to capacitance issues. It is either not building the charge or not dissipating the charge correctly. The drop could be a resistor in-line with a capacitor or a capacitor that needs an ESR meter on it to check the ESR value on EVERY capacitor that is in-line with the 300 volts that are not being made.
    Try this first (Get an ESR meter for the future, they are great for power supplies)
    Hope this goes well!
    THANK YOU
  • Andrew P.
    If you need the link, here is the DMD you are needing.
    http://compare.ebay.com/like/27073100867...*I7&GUID=5ee513a512e0a02653071e27ff62d414&itemid=270731008672&ff4=263602_309572
    Prices on these have seemed to come down quite a bit...They used to be in the $600 range.
    Thanks
Unit will not power up
the lamp may be faulty needs replacement, another culprit is the color wheel when worn out they tend to get stuck and cant spin hence the clicks as tries to spin needs replacement most color wheels come inbuilt in the light engine u will need a tech to replace it and u are good to go remeber the lamp cant turn on if the color wheel is stuck cos its the one that syncrinizes with dmd board which in turn activates the ballast board to fire or light the lamp
Jul 15, 2013 | Sony BRAVIA KDL-V40XBR1 Television
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
Black screen with sound. we replaced the lamp but screen is still black.
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. Also make sure everything is properly closed (door cover) if it's not properly shut it won't be able to light the lamp.Have a bless one!
Mar 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
My dell e1404 laptop is having a issue with the screen. When you turn on the computer the screen will come on for about 30 seconds and then go off. When it's on everything looks normal. once it goes out...
The inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. The inverter board converts low voltage DC power (few volts) supplied by the motherboard to high voltage AC power (few hundred volts) needed for the backlight lamp.
When the inverter board works properly, the backlight lamp gets power and the LCD screen lights up. As a result, the image on the screen is bright. If the screen is dimming down, means that the inverter is failing in it;s job to supply the needed voltage to the Backlight.
The Inverter is mounted underneath the display screen and is connected by a two wire plug.
Nov 07, 2009 | Dell Inspiron E1405 Notebook
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
The lamp indicator turns on
The clicking noise is the protection switch that keep shutting down the unit. This happens when an internal fault had been detected.
Do the following:
Unplug the unit from power for some time.
Remove the bulp and refit it in place.
Restart the unit.
If still in protect mode (clicking , lamp light and no start), then there is a fault.
When the problem is the lamp, the lamp light will come on, but usually protection does not click.
Before buying a new lamp that is expensive, have the projector checked, testing with particular attention the high voltage board that will supply power to the lamp. That may be the fault.
If you have a replacement lamp in storage replace the lamp first.
Jul 20, 2009 | Dell 2200MP Multimedia Projector
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
Screen takes several power up attempts to fire up
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 18, 2009 | Dell Latitude C840 Notebook
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Televison & Video Logo
73 people viewed this question
Henry  Thomas
Henry Thomas
