Question about Water Heaters
I have a 40 gallon rheem water heater for a mobil home that is leaking from the top.
  • Jake Gibson
    Jake Gibson Feb 23, 2016
    I'm sorry to hear about your 40 gallon water heater leaking from the top. My parents had a similar situation happen to their water heater last spring. I think they ended up getting a few bids from some licensed, experienced, and reputable professionals. I'm not sure if they ended up needing a new one or just getting their old water heater repaired. Good luck, I hope it's an easy fix! http://www.333help.com/water-heaters/
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Water-heater-is-leaking.html
Open following link if you want to install your own gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
40 gallon electric heater at Lowes costs 207, and is easy do-it-yourself using same basic information shown in link above for installing gas heater, except less work.
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
Trailers require specific type of gas water heater, so be sure to request correct model.
If you maintain the tank: keep chemicals out of same room as gas water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean gas burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Posted on Apr 08, 2011
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
I have Rheem model 41V50 leaking from the top...The top is a lid with screw....can I buy and replace the top ?
No.
Replace tank.
Buy 40 gallon from local Lowes and install yourself.
Under thin metal shell is a welded steel tank, surrounded by insulation and then covered with painted metal shell. The shell is what you look at.
The inside steel tank is made to withstand high pressure expansion that comes with heating water.
The steel tank has rusted out.
Turn gas control valve to vacation, so pilot light stays on, and then only heat enough water as needed until you can replace tank.
Prevent next tank from rusting by replacing anode rod, and ground water pipes.
Apr 09, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
Sep 17, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 41v850 leaking at bolt on top
just turn off the gas valve for pilot light, turn off cold water to water tank. drain system. when refilling open cold water to fill tank, wait at least a 1/2 hour to 45 minutes then relight water heater. you should be fine!
Mar 29, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a 21v40-7 rheemglas waterheater that is leaking from the line where the blue cap and the white water heater meets why is this happening?
If you see water at the top of the water heater you should take a rag and dry everything well, you should be able to see where the leak is from, if it leaks from the metal "housing" up you probably need a new water heater
Jun 28, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rheem glas fury model 22-40 gas water - leaking
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
256 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
