Question about Microwave Ovens
The turntable on my microwave does not work the model no is ken cj/al28
  • Microwave Ovens Master
  • 9,174 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You should be able to find parts here. If not, someone here should be able to direct you.
Posted on Aug 08, 2008
SOURCE:
Kenwood ken cj al28
You probably loaded the turntable too much. There is a small compartment on the bottom. YOu have to open this to access the motor. Replace the motor.
Jan 12, 2014 | Microwave Ovens
Kenwood Microwave oven CJ/AL28 The turntable is not rotating. Have tried moving the piece underneath glass and it is locked in position. How can I resolve this issue? Many thanks S. Heal
Hi and welcome to FixYa, I am Kelly.
POWER OFF / UN-plugged
To gain acces to the motor the outer chassis must be removed. 4 side scews and 6 rear screas.. then life the rear of the outer cabinet 10 degrees and slide it aft to unlock the front tabs. Then remove the cover. Before you do anything; take a good screwdriver held by the handle and ground the HV capacitor 3 times across the 2 terminals to prevent a horrible shock.
The turntable motor will accept input (0utlet) power when disconnected and a test cord connected to the turntable motor PN TYJ5807A. Some of these are 24 Volt motors... make sure you look on the motor to determine the voltage. You can test the motor for resitance on R x 1,000 scale. I should read resistance to the 2 terminals only and NOT to the case. If it reads from either terminal to the case the motor has failed. The windings in these motors are MUCH thinner than human hair. http://www.buyspares.co.uk/search.pl?query=TYJ508A7
or
http://www.4kenwood.co.uk/cgi-bin/product.pl?PID=944115
Take a good look at the motor drive post and make sure it matches yours. I could not find an exact parts break down for the CJ/AL28 but most turn table motors are common in a brand.
Thanks for choosing FixYa.
Kelly
Nov 28, 2010 | Emerson Microwave Ovens
Russell Hobbs HOB CJ/AL28 Microwave not worring
it is easy to fix if you know what to do but it is best sent to a local repair shop
May 01, 2010 | Microwave Ovens
Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Dec 03, 2009 | Zanussi ZMC30STQX Convection Microwave...
KEN CJ/AL28 Microwave
you should try a local wal-mart or even radio shack as these bulbs are somewhat common in many small appliances. Also, you may check at a local appliance repair shop.
Mar 24, 2008 | Microwave Ovens
Microwave Ovens Logo
113 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
