Question about Motorola Mobility i355 Cellular Phone
I355 service restricted how to fix this - Motorola Mobility i355 Cellular Phone
Motorola i355 requires codeto unlock
Search forgot code i355 in Google and choose the Motorola FAQ.
Jun 03, 2014 | Cell Phones
How to free motorola i355 from the lock
Hi. do you want to make your Motorola i355 free from network lock? If so, you need to unlock your device by entering an unique unlock code. You can get the unique unlock code for a Motorola i355 from TheUnlockArena.Com at affordable cost with easy unlocking guide. Good luck mate.
May 30, 2014 | Cell Phones
Where can i get free sim unlock codes for motorolla i355
Hi!
In this case the best will be to get in touch with your carrier to verify if it's possible for them to share the code with you or if there is any requirement they have for you ask for it.
Regards,
Gaby R.
Motorola Support.
May 28, 2014 | Motorola Mobility i355 Cellular Phone
I have i355 motorola phone bought it from my freind from canada but in my location its not working, so please tell me how will it work in my country
May be the mobile is locked with a Canadian Network.Try inserting other sim cards and even then it is not working then definitely your mobile is locked.You need to enter the unique unlock(subsidy) code for the mobile to break from the restriction.You can get the unlock code for your Motorola i355 from http://www.theunlockarena.com/motorola-i355/rs16wp9/ and remove the network lock easily by specifying the country and network to which the mobile is locked to.
May 07, 2013 | Motorola Mobility i355 Cellular Phone
My nokia 6280 need restriction code
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Jun 01, 2010 | Nextel i355
How do i change the lauguage from spanish to english on the i355 nextel phone?
From the main menu, select Settings >
Display/Info/Language
May 13, 2010 | Nextel i355
go to menu options to setup and you should find a language option.
Mar 23, 2010 | Nextel i355
My phone is restricted. It says "ready" on the display. How do I unrestrict it?
You are having an issue with your service. Nothing you can do manually. Call Nextel. If your carrier, "Nextel" isn't present on the display then you have a service issue. Ready means that an emergency call will work but you can't make or receive calls.
Apr 15, 2009 | Nextel i355
Motorola i95cl
unfortunately the i95 uses a 32k sim card and your i355 uses a 64k card...
Apr 13, 2009 | Motorola Mobility i95cl Cellular Phone
Motorola Mobility i355 Cellular Phone Logo
103 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
