My screen size has gone really big (p size setting on 16:9), how do I get back into a normal wide screen mode within the p setting ratio. For example, the words are now have off screen?
Look for button labeled ratio, push as many times as it takes to get right size,usually 16:9. If you are using a cable box/satellite box the pix size could also be adjusted within its menu. but first be sure the TV is properly set to 16:9
my samsung has a blue button on the lower right side of the remote the botton is labled (P-size) pressing the button cycles the set for the several screen size functions.--Wide Fit--4:3--16:9. If you are watching network TV on an antenna you will get a full picture on 16:9, but you may be watching on cable without HD.
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but: 1. Press [SCREEN MODE], to switch the TV aspect ratio. 2. Press [SCREEN MODE] repeatedly until the normal screen displays. NOTE: • Some programs may not offer all display mode options. 4:3 Programming [Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen. [Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen. [Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off. [Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal. 16:9 Programming [Full] A picture is displayed at 16:9 size as it is. [Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size. [Cinema] Cinema displays a 16:9 picture with vertical elongation. [Expand] Expand displays a 16:9 picture with horizontal elongation
You may record in either wide-screen or normal mode. If you record in wide-screen mode, the video will appear compressed when played back on a normal TV. For full details refer to the "Using the wide mode" section of the manual on page 32 of the manual.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2) Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
hi bob
you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only)
Note When TV signal is input in AV mode ,select “Screen Fit “to adjust
vertical position in 0-6 levels. Image Size Note
Supplied for the wide models only such as 16:9 or 16:10.
You can change the size of the screen displayed on your monitor.
PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals.
Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed.
AV signals
• 4 : 3 - Sets the picture to 4:3 normal mode.
• 16 : 9- Sets the picture to 16:9 wide mode.
• Screen Fit- Use the function to see the full image without any cutoff
when DVI (480p/576p/720p/1080i/1080p) signals are input.
Note
It can only be selected if an external input is connected to the DVI
terminal and the 'PC/AV Mode' is set to 'AV'.
• Wide-Sets the picture to 16:10 wide mode.
Note
• It can only be selected if an external input is connected to the DVI
• When the panel is of 16:10,the screen size options include
“4:3”,”wide “,”Screen fit“.hope this helps
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
• 16:9 : Sets the picture to 16:9 wide mode.
• Zoom1 : Magnifies the size of the picture on the screen.
• Zoom2 : Expands the Zoom1 format picture.
• Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
• 4:3 : Sets the picture to 4:3 normal mode.
• Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
