Question about Maytag Dryers
Dryer heats but fan or drum does not work - Maytag Dryers
  • 42 Answers
Check the belt that turns the durm, it may also turn the fan.
Posted on Apr 08, 2011
Roper dryer works on high heat only
DID U CHECK THE HI LIMIT AND THE CYCLING THERMOSTAT? AS WELL AS THE MOISTER SENSOR?
Dryer venting issues slow drying, fire flare ups, to hot, noise and clothes ripping etc
A lint filter that is full of lint will restrict airflow and lengthen dry times.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit.
In gas dryers, defective gas valve coils can create a symptom of taking too long to dry if they are intermittent. Check for proper flame ignition for the complete dry cycle to determine if this may be the cause.
The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear bulkheads. The drum seals are made up of a felt like material. If the seal is torn or is worn then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them.
DOOR SEAL When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum.
The vent tube or line itself. If it is kinked, smashed, to long, or filled, clogged with lint build up it can not only cause slow dry times but create a fire safety hazard. Try to stay away from using plastic or flimsy cellophane venting, aluminum is best!
To provide better air flow and heat dissipation try the following
Note the length of your dryer vent is a determining factor in how efficient your dryer will perform. If the total length of your pipe exceeds 25 feet then your dryer simply won't be able to perform as should, especially if your pipe runs vertically and through the roof. This is where a booster fan is sometimes needed. Booster Fans provide the extra push of air to exhaust the moisture and lint to the outside. These fans operate only when the dryer is activated, this is done by sensing the air flow through the pipe by a pressure switch mechanism or an electrical sensing relay which in turn activates the booster fan blower. I personally try to avoid adding booster fans simply because they are usually placed in a crawl space or attic and are therefore "Out of sight and out of mind." What I mean is... the unit could malfunction and you would never be aware of it. The result would be a restriction in the pipe which would cause a build up of lint at the fan. In addition, it's recommended that lint traps be placed before the fan itself which has to be cleaned out frequently. These can also easily be overlooked.
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Mar 28, 2016 | Roper Dryers
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Cmd146 dryer heating top chamber but not in drum
It sounds as though the fan motor is faulty, usually these motors distribute the heat from the heater box into the drum. Because the heater box is getting hot I doubt if the fault is the thermostat so it may well be the motor or associated wiring
Mar 29, 2017 | Candy CN146 Front Load Washer
My asko dryer 7005 works the heating element but the drum d,not turn
broken belt , defective timer, defective board if electronic, defective push button start switch, defective cintrifugal switch in the motor itsself, defective motor, foreign object blocking fan motor in housing, stuck drum rollers.
Mar 02, 2012 | Asko Dryers
The dryer does not seem to push hot air into the drum. The heating element works in that I can feel it being hot, but there does not seem to be much, in any, hot air being pushed into the drum.
Make sure that the vent is not blocked. Also check that the fan is not broken (reasonably common). The fan is bottom right once you remove the front panel.
Dec 11, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
The drum rotates. and the heating element heats up and smells . fan is working intermittently. my guess is, its the fan.
is it noisy like the fan is loose on the shaft" most fans are direct off motor
Sep 25, 2009 | Dryers
Replaced the heating element what ever its called. and still not heating up' its politless
Disclaimer: I don't know this particular model, but in general, tumble dryers have 2 or 3 interlock switches that need to be checked:
1. Door interlock: this allows the drum motor and fan to energise and the heating element to be turned on: Does drum turn and fan come on? If so, it is not this.
2. Overheat switch: located in exhaust path of fan: usually re-settable - have you located this and reset it?
3. Humidity sensor (some models have this, some work on time only) - this can fail open circuit and the drum and fan won't come on. (Same check as number 1)
Jul 29, 2009 | Kenmore Dryers
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
