Question about Systemax SYX Crossfire X58 Gamer Intel Core i7930 28 GHz genuine Windows 7 Home Premium 64 Bit 12GB (SYX1040) PC Desktop
The computer won't boot Windows 7. It starts up fine, with the fans running with the LED lights on. Then I get an error message: "CD-ROM Boot Priority ..No Medium" I have checked the bios of the computer and have put the boot priority to my HDD but I just get a black screen with a flashing underscore. I have tried booting with the Windows 7 recovery disk and have recovered the PC to a factory setting and it still gives me the same error. I have a ASUS Sabertooth x58 motherboard if that helps. Please help! Thank you!
  • 59 Answers
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Posted on Apr 08, 2011
  • 1,218 Answers
Check the following information for windows 7 reinstall.......
Posted on Apr 21, 2011
@PcFixx Col Just a quick question, how could I reinstall windows 7 without being able to get past the black error page? Thank you for the quick reply!
  • jonathan mcneilan Apr 08, 2011
    As long as the only error message is that there is no medium in the CD drive you should be able to do this. All you need is the Windows 7 install disc. If you are having other issues please let me know and I'll try to address them.
Error message "NTLDR is compressed" how to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
Ntldr is missing at startup
To fix your problem please follow the below steps.
1. Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further.
2. Restart your computer.
3. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer.
4. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear.
5. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
Thanks for contacting Fixya. Have a good day.
Aug 10, 2011 | Dell Dimension 4600 PC Desktop
When i start my pc it display NTLDR file missing
Here ya go!
http://www.tinyempire.com/notes/ntldrismissing.htm
Jun 14, 2011 | Computers & Internet
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
Solutions
Feb 19, 2011 | Microsoft Computers & Internet
Ntldr cd boot fault
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Mar 31, 2010 | Computers & Internet
My computer wont start...it keeps saying missing NTLDR?...what do i do?
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Sep 20, 2009 | Computers & Internet
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
NTLDR is missing
Cause:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
Solutions:
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
Systemax SYX Crossfire X58 Gamer Intel Core i7930 28 GHz genuine Windows 7 Home Premium 64 Bit 12GB (SYX1040) PC Desktop Logo
395 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
