Question about Refrigerators
Ice maker stopped producing ice. waterfilter is out dated, but still producing good tasting water. would water quality stop ice maker from working.
  • 6,993 Answers
Investigate each of these two areas if your ice-maker is not making ice;
1. Water Inlet Valve
2. Defrost Thermostat
Water Inlet Valve: Your ice maker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
An ice maker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
Follow the below directions to test your water inlet valve;
Before you begin to test your ice maker's water inlet valve, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this test.
1. Locate your icemaker's water inlet valve, it is typically located behind a refrigerator. Gently pull your refrigerator away from the wall. You may want to place scraps of carpet, of some other soft material below the fridge to prevent damage to the floor. Turn of the water valve's water supply by closing the shut-off valve in the waterline leading to the water valve. Remove the lower access panel on the back of the refrigerator using a screwdriver or a nut driver.
2. Place a container under the valve to catch any water that may spill from the water valve and its fill tube. Remove the water valve's fill tubing. Loosen the flare nut on the brass fitting that is found on the inlet side of the water valve. You can use a wrench to loosen the flare nut.
3. Your water inlet valve is held in place on your refrigerator by means of a metal bracket. Use a screwdriver or a nutdriver to remove the screw that holds the water valve's bracket to the refrigerator cabinet. Gently pull the water valve out of the cabinet, and remove the tube from the outlet port.
4. There are two wires connecting to the terminals of your water inlet valve. If yours is a double solenoid water valve, it will have four wires. Be sure to label each wire so that you know where to reconnect them later. Firmly grasp the metal connector of the wires in order to remove the wires. You may need to use a pair of needle-nosed pliers. Do not pull on the wires themselves.
5. Set your multitester to the R X 1 ohms setting to test for continuity. Place each of the multitester's leads on a terminal. Your multitester should display a reading between 200 and 500 ohms. Closely examine your water inlet valve. The exact ohm resistance rating you should test for may be marked on the valve.
6. If the test you conduct with your ice maker water inlet valve does not produce these results, then you should replace the component.
Defrost Thermostat ;
It could just be that your freezer thermostat is not set low enough. Try adjusting the thermostat to a colder setting. Or your ice maker might not be making ice because of a defective defrost thermostat. Test your defrost thermostat to determine if it has malfunctioned. If it has, you will need to replace it.
Directions for testing a refrigerator defrost thermostat;
Before you begin to test your defrost thermostat, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
Follow the above closely and I believe it should guide you in solving the problem;
I hope this helps.
Good luck.
Posted on Apr 08, 2011
It has almost been a month and I would like to enjoy ice that doesn't taste like plastic/plants. What can I do?
you may have algae growing in the ice maker that is producing that taste
remove the ice maker and clean properly including all water lines to the maker
May 26, 2016 | Refrigerators
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Ice maker in Kitchen Aid stopped making ice
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replaced icemaker with new one but still not working
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG refrigerator french door icemaker not working
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
Oct 10, 2008 | GE Refrigerators
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
