Question about Phoenix Gold Phoenix Digital 7.2-inch LCD Color Monitor
I bought the phoenix digital PD-7.2 inch widscreen monitor to go in the car and i cant see how to plug it in? I dont think it came with a plug can you help?
2 Suggested Answers
SOURCE: Phoenix Gold PD-2999D Car DVD... Problem:
I bought a Universal Miniature AV Remote, then just started stepping thru the devices and codes. I got lucky and found it
To eject - push the Orange button, top Right.
Posted on Jun 21, 2008
How many watts will i need for the pheonix pd 131 1000 watt speakers.
You should get yourself at least a 250watts rms amplifier. The peak power handling is 1000 watts, otherwise called short term power . Average power would be about 1/4 of that to be on the safe side i.e 250watts.
Jun 02, 2011 | Phoenix Digital PD-133 Car Subwoofer
What type and size of box should i use with this
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
May 26, 2010 | Phoenix Digital PD-131 Car Subwoofer
My BIOS info is Phoenix Technologies, LTD R01-B3,...
Im not sure but I dont think so open your bios and it shoud tell you if it is supported
May 20, 2010 | Acer Aspireā„¢ T180 PC Desktop
My computers sound driver
1 . Right-click on My Computer and click on properties
2. Under the Device manager tab select on the Device manager
3. Now double click on the System Devices → Right click on the Microsoft UAA Bus driver for High definition audio and disable it
4. Now Uninstall it
5. now again install the driver for the Audio Driver
6. Reboot and Enjoy
Read more: http://comsguru.blogspot.com/2009/11/install-realtek-hd-audio-driver-failure.html#ixzz0nMLSq8px
May 06, 2010 | Phoenix Digital PD-174 7.2 in. Car Monitor
Look i have a phoenix digital PD 395 and when i
some amps require more than 500 milliamps to keep it "turned on" most head units put out half of that ,bosch relay inline from deck to amp turn on post should do it this will give the amp a full 12 volts to turn on and stay on . first try to hit the maps with a jumper with 12volts fused , see it it stays on
Jan 07, 2010 | Car Audio & Video
Amp on "protect" mode
Hi, what you need to do is unplug all the connections to the amp. The amp goes into protection when the circuitry over heats.\
First decrease all your gains to minimal volume.
Connect your 12+V, remote, and ground.
See if the protection light comes on then.
Next plug in your RCA cables.
Check protection light.
Then plug in your subwoofer cables.
See if you are still in protect mode.
Hopefully everything works alright again.
Just slowly increase the gain to see what the cut-off is. Make sure you aren't dropping the ohmage too low on the amplifier. Check manual for correct wiring and such.
Feb 08, 2009 | Phoenix Digital PD-394 Car Amp
Mar 12, 2008 | Phoenix Gold PD-2999D Car DVD Player
Phoenix digital pd234
First of all did the set get wet? If so, It needs the boards washed Immediately! Spray boards with windex soak em up. Need to remove all salt deposits and minerals or the boards traces will rot.Then rinse with distilled water let dry Then you could save this set. check this site They rebuild assorted stuff cheap. www.irionstvshop.com
Feb 23, 2008 | Phoenix Digital PD-VIVID 7 in. Car Monitor
VIDEO CABLE & MOUNTING HARDWARE F/ PD-174
Hi Coleman,
Nothing really special needed unless you get it running and you have lines or snow on the screen. You can use a the PS2's A/V cable, just run it on the opposite side of the car from the power. Also, you will probably need more length than the average PS2 A/V cable has, so Splice in some length. As far as mounting, Most of the time, I fashion an adapter to connect into the bracing for the dome lamp. You might get lucky and find a Bracket made for the Expedition. If you do not like the postition of the Dome lamp, thge roof of the expedition should have ribs. You can make some cross beams to span betweent he Ribs and allow for mounting your Monitor.
Nov 06, 2007 | Phoenix Digital PD-174 7.2 in. Car Monitor
Phoenix Gold Phoenix Digital 7.2-inch LCD Color Monitor Logo
67 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
