My monitor did not work,i cant open it,have no power on
  • 68 Answers
Check the power cable... unplug and replug the power cable... try directly in the wall socket....if you have surge protector... try different power socket.... try different power cable swap power cable for monitor and comp...
Posted on Apr 08, 2011
Troubleshooting, cant open my tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Televison & Video
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
My monitor hp 1702 is saying monitor is going to sleep. I cant even get my cd part to open windows xp professional 1-2 cpu hp
It sounds like you have the problem with the PC itself, you can try this monitor with another PC just to narrow down the problem.
The PC mayhave hardware problem usch as bad power supply that may explain why you cannot even open the CD tray.
Jul 12, 2011 | HP L1702 17" LCD Monitor
Cant turn monitor back on
broken power switch... .. the "friend" broke the power switch by pressing too hard or as luck had it the switch is broken..
recommend leaving the monitor unplugged for 4 hours
open the case of the monitor up and pull the small circuit board for the "buttons" out and get a replacement board... google the part number exactly as spelled out on the little button board
Sep 28, 2009 | Computers & Internet
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Issue with my 17" Viewsonic VA1716w LCD monitor
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Dec 10, 2008 | Computers & Internet
Power blink
Horizontal output transistor is shorted or flyback problem
Oct 17, 2008 | AOC CT720G 17" CRT Monitor
Power supply
it is not the power cord you should chk for th video cord. it mean there is no siginal coming from the CPU.
Thanks for using fixya. Hope this solution may have helped you.
Jun 17, 2008 | Dell E156FP 15" LCD Monitor
Acer aspire external monitor not responding.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 22, 2008 | Computers & Internet
Computer turns on, but there is no display on monitor.
The builtin video card is probably bad. Yes, you can get a PCI video card.
Dec 28, 2007 | Dell Dimension 2300 PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
