Question about Belkin F5X007 XM Radio Receiver
How can I get a replacement battery door cover?
Battery replacement J-10A
Good Morning Fhaas153
Looking at a J-10 picture on eBay
http://www.ebay.com/itm/VINTAGE-CASIO-J-10-ELECTRONIC-CALCULATOR-8-DIGIT-TESTED-/331587643662 , the picture of the rear says '1.5V battery x 2. Looking at this other shot
http://www.casio-calculator.com/Museum/Calculator/FGHIJ/J-10/Casio-J-10-back.jpg It looks like there is a fairly clear Slide-to-Open Battery door at the top of the rear panel. Given the battery rating at 1.5 Volts and the door size, I'd suspect it'll take either AA or AAA batteries. You should be able to slide the door and look, and most battery compartments will have an indication of the specific cell.
To be sure I'm covering both the what and the how, slide the door open. Remove old batteries if still there. Clean up contacts with a bit of fine steel wool if they are corroded or covered with old battery fuzz. Put new batteries in - negative end towards the coil springs generally. Replace sliding hatch.
Hoping this covers what you're looking for!
D
Dec 09, 2015 | Casio Office Equipment & Supplies
Kodak CX6200 Battery Door Replacement
Link to purchase of battery door with instructions
Dec 05, 2007 | Kodak EasyShare CX6200 Digital Camera
Batteries dead on my Sentry E163026 safe dont know what to do
A1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Fireproof Safe
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
How to change batteries on ku916aa
1. There should be a cover on the bottom with a release lip the batteries are here to replace. this is located right below the on/off button.
May 29, 2010 | HP Wireless Optical Mouse
Battery cover door won't stay on
you should please seek the companies tech support. sometimes the should replace the phone .this is a manufacturing defect.
Dec 18, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Battery door
Bushnell Repair Center
8500 Marshall Drive
Lenexa, KS 66214
Jul 16, 2008 | Bushnell PinSeeker 1500 20-5103...
Canon digital camera
Same problem here with broken battery cover door! Called Polaroid and NO they do not have these parts to replace....if the camera was under warranty Polaroid would have replaced the entire camera.....soooooo when you find out any info as to where to get the battery door list the info! Thanks! & good luck too!
May 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
How to replace battery door?
I just replaced my battery door. You have to take every screw out of the camera. I used a philips eye glass screw driver. Then, pull the front and back covers apart carefully, its only plastic. There is a pin that holds the door to the rear cover. If you push the battery door button back and fourth the pin will start to show out the side of the camera. I pulled it out once it showed with small pair of needle nose pliers. Just reverse the procedure to install the new door.
Dec 12, 2006 | Canon PowerShot A20 Digital Camera
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
Belkin F5X007 XM Radio Receiver Logo
49 people viewed this question
Top Belkin Audio Players & Recorders Experts
ocgordy
Level 1 Expert
woodzowl307
Vernon Taylor
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
