Question about Lexmark X3650 Printer
My lexmark x 3650 states there is paper jam. it never happened. i was low on black ink but have just replaced cartridge. how do i clear/
  • Official Brand Answer
  • 3,344 Answers
Try to remove the sheets of paper from the feeder. Open the printer and remove the cartridges. Then unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper. Try to print again.
Posted on May 03, 2011
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Paper jam
Usually ink cartridges get damaged because they get dried up. It usually happens in the areas with low humidity. In that case, you need to add a humidifier to the place where the printer is kept. If the problem still persists, then you may have to replace the ink cartridge.
Jan 19, 2011 | Lexmark X2600 InkJet Printer
My Lexmark 8300 is making a rumbling noise and it seems like the print cartridges are getting stuck on the left side. The black ink cartridge is low but it is not printing light so I haven't switched it...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
I have Lexmark x85printer. Bought new Ink Cartages. Printer Will not Feed Paper All I get is paper jam Clear paper
Either the ink cartridges are incorrectly inserted, and block the paper path jamming the paper, or the paper drive roller got slightly out of kilter when replacing the ink. Sometimes, powering down the printer, manually moving (gently) the printer head halfway from home position, closing the printer and powering it on will clear a roller problem (never tried on a Lexmark, though. It works on Epsons and HPs). If the head doesn't move, though, don't force it. Try instead taking out the ink cartridges and putting them in again, without forcing, and gently wiggling them until they click in place.
If you get the message without any paper in the printer, check the insides for any scrap of paper which could have lodged in the sensors.
Also, verify there is no paper elsewhere in the paper run (paper out tray, etc.). Sometimes the "paper jam" message is a sort of "catch-all" error.
Nov 04, 2009 | Lexmark X85 All-In-One InkJet Printer
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
What should I do if my Lexmark X 1270 keeps on paper jamming?
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 22, 2009 | Lexmark X1270 All-In-One InkJet Printer
Paper jam indicated but I opened the back and can't see any paper
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects. Most of the sensors are either a microswitch, or more commonly a light sensor (LED and photocell) which can easily become obscured or dirty with even a tiny bit of crud! also reload the printer drivers as the printer is not beem able to read that new cartridge has been installed. and dont just directly install the cartridge .install it through a procedure.as mentioned in the printer properties .---ink cartridge replacement option----- as canon printers do very much drama to detect some cartridges and sometime just works fine.
Nov 21, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark X83 - Changed the black cartridge according to the instructions. Message says Warning low on black ink. Page prints so faintly can't be read.
refix again cartridge also check there is not any paper jam or lekage in cartridge.
clean on bottom surface of cartridge on which u put it.
Oct 22, 2008 | Lexmark Office Equipment & Supplies
Lexmark X8350 jams (and other problems) after ink cartridge refill
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Apr 29, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
Lexmark X3650 Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
