Question about Toshiba DR410 DVD Recorder
I am getting an E6 error code when I have programmed by player to tape a program. It shows up on the left hand side of the set timer page.
2 Suggested Answers
Demonic-2011
  • 472 Answers
SOURCE: I'm thinking of buying this VCR/DVR combo -
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Posted on Mar 09, 2011
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I can't find my manual. I need to hook it up so that I can record tv shows I like to watch when I am not home. But I didn't do it right and I am having trouble with the remote also.
You can download a manual from http://www.funai-corp.com/support/manuals.aspx . Click on Customer Support and then Owner's Manual. Remote problems - first try new batteries then try a universal or other replacement remote, http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWD2203+&uuid=12828737757670 .
For problems with timed recording, make sure the clock is correctly set. If power goes out for more than 30 seconds, the clock will be incorrect and the timer information will be off. Insert a blank tape (or one you want to record over). Then press Menu and then go to Timer Programming. (Use the up/down arrows and then hit the right arrow button.) Set the frequency of recording followed by the day and start time of the programmed recording. Then set the end time of the recording. Next set the channel number. (with some set top boxes and TV connections, choose 3 or 4 depending on the way the setting of the RF output. Then set the channel on the set top box and leave the box on.) Then set the recording speed. Press T-set to lock in the program. If you want to watch a tape before the program starts, press T-set (turning off the timer light). Remember to press T-set afterwards to resume programmed recording. You can't record to DVDs.
I hope this helps.
Aug 27, 2010 | Emerson EWD2203 DVD Player/VCR
Govideo model dv2130
You should be able to get into a list of timer recordings by this method:
1 Open “Initial Setup” menu
Press the SETUP button or the TIMER button while the DVD is in
Stop or Play mode.
2 Select “PROG”
Use the ??/?? buttons to highlight “PROG” then press the
ENTER button.
3 Select the recording to be deleted
Use the ?? and ??/?? buttons.
Press the ?? button to move to the next setting.
The squares are the arrow keys! You should be able to delete the settings using these keys or some other key.
Next time you set a timer recording make certain you don't set the weekly setting!
Apr 29, 2010 | GoVideo Go Video DVD/VCR Combo
I need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Feb 16, 2010 | Samsung DVD-V9800 DVD Player/VCR
Everytime I go to BEBO page I get a Internet Explorer error and it closes internet down only on this site HELP !!! Internet Explorer has encountered an error then closes down
goto
www.firefox.com
download free broswer, and install, do not import your Explorer settings
goto www.java.com
install the free java program
goto www.macromedia.com (it will take you to an adobe page, since they bought the company) on the lower right hand side of this page there is a link to download the free flash player.
close the browser. run the install firefox program, if you have not. run the flash install program, and the java install program if you have not. be sure to follow my order.
restart you computer
now you can goto to BEBO with firefox
never use Explorer again.
Jun 28, 2009 | Computers & Internet
Pre-Set Timer program not recording
Just a hunch, but did you check the clock settings after the time change?
Nov 08, 2008 | Samsung DVD-V3650 DVD Player/VCR
Timer recording, more than 1 show
I have no solution how to fix it. My idea is . Use the One-touch timer Recording (OTR) on page 27.
If your manual is the same as mine. My VCR recorder is broken.
Aug 29, 2008 | Televison & Video
Installing the software
close the program, go to desktop.. right click on empty space, select properties.
Then select the settings tab from the top.
now you need to pull the resolution into one or two settings higher.
go back to the program and its visible.
Aug 03, 2008 | Apple iPod touch
How do I find the vcr plus coned to enter into my recorder?
Go to the TV Guide web site:
http://www.tvguide.com
You have to choose your location by zip code and if you have cable, satellite, etc. Then you can choose the day of the week and the time and find your show. When you move the mouse over the show a window will pop up a synopsis, click in the middle of the pop up and it will open another page with info about the show. Scroll down a little and on the left hand side it shows VCR+ and Tivo info. I have not used this feature because I don't know if it will let you set something to record say on a weekly basis. I use my unit to record some TV series which play weekly at the same bat time and same bat channel! Plus this unit has 16 timer record slots, twice as many as any VCR and the programing is much more flexible, Good Luck.
Mar 29, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Toshiba DR410 DVD Recorder Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
