Question about IQAir HealthPro Plus Air Purifier
My IQ Air Healthpro Plus was purchased about 6 months ago. It resides in my bedroom - single floor home; high tech central air cleaner with uv lights. All of a sudden the past week or so my IQ Air machine is producing a "musty" smell. I checked the filter life - have nearly 2000 hours left. I've taken all the filters out and checked them; everything appears normal. Any idea how to get rid of the smell? Which filter I might try changing first? I'm at wits end!
How do i clean my Brookstone Pure-Ion Uv Air Purifier
[PDF]Pure-IonĀ® Pro - Brookstone
BrookstonePure-IonĀ® Pro. Air .... Use this unit only for its intended use as described in thismanual . 4 . .... Position the unit so the cleaner air flows to your desired location .
Aug 30, 2015 | Brookstone Pure-Ion UV Air Purifier
IQAir HealthPro Plus; need a replacement fan; anyone sells these other than shipping this back to IQAir
There is no listing for the fan IQ Air uses in its units, but you could pull the fan unit from the case and match it to one of the many fan motors at this
Jan 10, 2013 | IQAir HealthPro Plus Air Purifier
Why healthpro iqair will not start
Have you checked if it is plugged in?
Nov 11, 2011 | IQAir HealthPro Plus Air Purifier
Why am I ***?
I can solve this problem very easy
The reason you are is because you need
to perpetuate your genes
Jan 03, 2011 | IQAir HealthPro Plus Air Purifier
What company manufactures this product?
Try this link.
Dec 17, 2010 | IQAir HealthPro Plus Air Purifier
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
Apr 08, 2010 | IQAir HealthPro Plus Air Purifier
Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
Jan 02, 2010 | Air Purifiers
Replacement UV Lamp Source?
Dear Bill,
We have our custom dual frequency UVC lamps made here in AMERICA specifically for our SUN AIRE purifiers.
Our lamps are 9,000 hour lamps and should be replaced at about 18-24 months because it will lose its effectiveness to energize the air, thus no longer purifying your air.
The cost of our custom dual frequency UVC lamps is only $48 plus $5 SH. That equates to about $25 for your maintenance cost on our LIFETIME SUN AIRE PURIFIERS ~ MADE IN AMERICA! Please contact us at:
1-800-684-8253 and we'll get your new UVC lamp out to you within 24 hours.
We appreciate your business and look forward to serving you.
We'll be here ~ whenever you need us
Oct 10, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Help! My air ilter quit!
I bought one a year ago and never thought it work well in cleaning the air. I get more dust on my counters than collects in the pure-ion. I recently got a letter from an attorney saying they are settling a class action suit on these purifiers because the are not effective. I called brookstone and they said they will refund my money because of the law suit. Good luck.
May 10, 2007 | Brookstone Pure-Ion UV Air Purifier
IQAir HealthPro Plus Air Purifier Logo
242 people viewed this question
Top IQAir Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an IQAir Air Purifier Expert? Answer questions, earn points and help others
