Question about HP F4480 All-In-One Printer
My paper keep on getting jam everytime i print... please help
    Novelist:
  • 125 Answers
Have you check the paper feeder? any dust?
How about roller?
If you have air gun, pls try to get rid of dust as much as you can.
And then try back.
How u manage your cartridge every time when u are out of ink?
Try newly developed inkjet refill kit by "ROADINK"
It not only easy, but also, save your $.
Most importantly, give you great quality printing.
Check out the youtube movie clip and will c how easy refill can be done.
http://www.youtube.com/watch?v=72DKr8pUZKU
Posted on Apr 08, 2011
Keep on paper jam everytime i try to print paper feeder not align help me pls how to fix this one
check for something they may have fell into the feeder like peice of paper or thumbtack anything that would obstruct the paper path.
May 04, 2011 | Computers & Internet
How can you keep the printer from jamming up paper with every print everytime I go to print a paper the paper jams in the printer, I checked for jammed paper but dont know how to reset it
reset printer
check if there is any paper (small bits) stuck in the printer which could be blocking the sensor or the rollers
also check if the paper is not damp?
realign printer heads using the software if it offers the function?
Oct 16, 2010 | Cannon Office Equipment & Supplies
Paper jams??
click here to download yor required drivers
May 12, 2010 | Brother MFC 6490CW InkJet Printer
My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Canon PIXMA iP1600 Printer
No paper jam but still says there is a paper jam
Hello there even if you not see any thing jams it worth a try. There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Feb 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Says there is a paper jam everytime i try to print
Hello
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Paper continually jams
What is the error code from page 69 and 70 of the E-232 manual?
Here is the webpage to download anything that you may be missing. The manual has a very complete section on complete clearing of jams.
http://search.lexmark.com/printer/US/en/22S0200
Dec 22, 2008 | Lexmark E232 Laser Printer
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Peter
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
HP F4480 All-In-One Printer Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
