Question about Craftsman 24 Hp 48" Deck Yard Tractor
On my craftmen 5500 Kohler 24 hp' The engine surges,\while running. What could be causing this.
  • Phil Walker
    Phil Walker Apr 08, 2011
    The main jet in the carby needs cleaning out.
  • 608 Answers
The main jet is dirty or the fuel system is restricted. Regards Phil
Posted on Apr 11, 2011
Kohler kt735-3012 runs fine for a few mins then runs rough and burns rich
Ron, Try new plug/s first, sounds like the carburetor has dirt in it, you will probably have to remove carb. and clean/rebuild. From manual, other causes from your trouble shooting guide ,
? Faulty carburetor. ? Faulty cylinder head gasket. ? Faulty or misadjusted choke or throttle controls. ? Fuel pump malfunction-vacuum hose clogged or leaking. ? Intake system leak. ? Loose wires or connections that intermittently ground ignition kill circuit. ? Quality of fuel (dirt, water, stale, mixture). ? Restricted fuel tank cap vent. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kohlerengines.com/onlinecatalog/pdf/32_690_03_EN.pdf
Kohler KT735 3013 24 Hp Engine Parts
Kohler carb rebuild
How To Rebuild Kohler Series Carburetor K161 K181 K241 etc
Jun 27, 2016 | Garden
My Kohler 25 hp engine surging up and down at full trotal and stops runing if trotaled any lower
sounds like you have a govenor coming apart inside the motor.
Oct 23, 2012 | Garden
Mts 5500 tractor
I have a Sears MTS 5500 tractor, 24 hp, 48" mower, bought new 2008 but used very little; only 127 hours on it. Soon after starting, tractor emits a heavy white smoke. Tried changing the oil, no help. The engine is B & S Extended Live Series, twin cylinders, total displacement .725 liters. Any ideas of what is causing this?
Jul 21, 2012 | Craftsman Garden
Replacing 24 hp B&S with a 20 hp kohler, need to
Yes I agree. I would figure that out first before changing the engine.
Sep 07, 2011 | Briggs & Stratton Garden
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Aug 25, 2009 | Craftsman Garden
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Jan 16, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
208 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
