Question about Texas Instruments TI-84 Plus Calculator
Hey, how do you enter minutes into a TI-84? (I'm doing problems with degrees, and one has minutes added onto the degrees)
  • 3 Answers
The notation for minute is a single quotation, ' . To access this symbol, press the 2nd key, then the Angle key. The single quotation mark is the second option on the menu that comes up after pressing 2nd+Angle.
Posted on Apr 08, 2011
Sin 43 degrees 30'
Press SIN 4 3 2ND [ANGLE] 1 3 0 2ND [ANGLE] 2 ENTER
2ND [ANGLE] 1 gives you the degrees symbol, 2ND [ANGLE] 2 gives you the minutes symbol. If you need seconds, use ALPHA ["] (on the + key).
Note that this usually won't give you an EXACT value, but only a ten-digit approximation.
Dec 05, 2012 | Texas Instruments TI-84 Plus Calculator
When I hit dms function the answer comes out wrong the degree minutes = the degree and the seconds = the minutes how do I change it TI-84 Silver
At first, you have to use DEGREE mode and after that you can convert your angles into DMS mode. See captured image below
Oct 05, 2011 | Texas Instruments TI-84 Plus Calculator
I have a TI-84 calculator. I can't figure out the exact buttons to press to find the sec of -1.2. It is supposed to be an answer in degrees.
First, check if the calculator is in degrees. Do this by pressing mode and selecting degrees (it should be about the third option down)
The TI-84 doesn't have a dedicated button for secant so you will just have to enter it as 1/cos(-1.2) or cos(-1.2)^-1
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
Ti 84 mode a+bi you can not add 5 at 90 degrees to 5 at -90 degrees. You need to switch to exponential mode e^ and enter as 5 e^(pi/2i) this is ok for 180 degrees. however what do you do when...
You can add angle measures by hitting 2nd angle and choosing the degree option. Put this after a value (e.g. 90(degrees symbol)) and add you can add angles that way. Be sure that you are in degree mode when doing this (you can use the radian symbol for adding radians too). Still, this is a very tedious process and I recommend just adding angles as regular values (e.g. 90 + 200 = 290) and correcting for degrees manually.
Feb 21, 2011 | Texas Instruments TI-84 Plus Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
Wrong trig ratio
Your calculator is set in radians. Press mode key. Arrow down to 3rd line. Highlight degree and press enter. Your calculator is now in degrees, not radians. To get out of the mode screen and back to home screen, press 2nd and then mode.
Aug 05, 2009 | Texas Instruments TI-84 Plus Calculator
Minutes and seconds and degrees button
Here:
http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
Look at page 89 about DMS.
Rate me, thanks.
Jun 20, 2009 | Texas Instruments TI-84 Plus Calculator
Degrees, minutes and seconds button
Press the blue "2ND" button in the top left hand corner, then locate the "ANGLE" button, or "APPS" button and press.
It should give you a list of symbols.
The first two are: Degrees and Minutes.
As for seconds, press the green "ALPHA" button, then locate the "+" and press.
May 19, 2009 | Texas Instruments TI-84 Plus Calculator
Minutes
Yes. Use the following procedure to enter an angle in degrees-minutes-seconds form:
Enter the number of degrees. Press "2ND" "ANGLE" "1"
Enter the number of minutes. Press "2ND" "ANGLE" "2"
Enter the number of minutes. Press "ALPHA" " (double-quote above the +)
The ANGLE key is the APPS key.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
122 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
