Question about Pyle P3001at 2Channel Amplifier
How to fix pyle p3001at humming when master volume at zero
  • Pyle Master
  • 5,151 Answers
Chances are this is caused by the big electrolytic capacitors in the power supply. They filter out the 50 to 60Hz hum in mains electricity. When they fail it gets in!
Posted on Apr 19, 2011
Sound used to be clear. Now have static. Is my pyle PT54 digital tuner bad? I also get a loud hum when the unit is tunred off.
Sorry, but Pyle isn't good gear. If you've checked all the wiring and nothing else has been altered then I'd point the finger at the Pyle-o-c***
Sep 03, 2014 | Pyle New-Home Pt504 Rack-mount Am/fm...
How do i fix the humming in the volume
If the audio output IC is faulty, Hum will be heard, even if the volume level is set to [Zero].
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 27, 2014 | Dynex Televison & Video
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
For some unknown reason the db meter on the display stopped working and the volume wont go up very high at all?
Got a feeling that this amp might be powered by a big IC somewhere that's failed. Perhaps something looking like this:fffa1d0d-4877-4ce2-b3fa-89d116a21d5f.jpg
Apr 09, 2013 | Pyle Pt3300 Amplifier
When I hook up my computer to the receiver and play music it is hard to find a point on the master volume where the music plays clearly. The music skips and i have to be very careful with the master...
Master volume control pot is dirty and needs to be cleaned out. You can do this by unplugging the receiver and turning the master volume control back and forth from zero volume to full blast a couple of hundred times to clean the surfaces and restore normal operation.
Aug 24, 2017 | Pioneer VSX-509 Receiver
Where do I set switch for pyle pvc2 volume control
I had the same issue and recieved info from PYLE. See attached picture for switch settings and terminal screw identification. Kp
Jul 01, 2010 | Pyle Slide Volume Control
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
I'm experencings a buzzing noise coming from the speaker when I turn on the tv....How can I get rid of this noise?
Give this a shot, it should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
Let me know if this works.
Feb 19, 2009 | Proscan 32LB30QD 32 in. LCD TV
Pyle P3001at 2Channel Amplifier Logo
197 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
