Question about Frigidaire Dryers
Where is the thermal fuse in the frigidaire fdg336re
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: were is the thermal fuse located on the frigidaire fde336res1
It is located on the rear bulkhead upper right hand corner. Ti access it you pop the top with a putty knife and remove the front panel. Get the drum out. I recently worked on one and did a video:
http://www.youtube.com/watch?v=wkog1i53T_k&list=UUKBjalPycKRmo4Mz9vRsydg&index=10&feature=plcp
http://appliancejunk.blogspot.com/2011/08/frigidaire-gallery-dryer-revamped.html
The smaller disk is the fuse. If blown the dryer will not run
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Posted on Jul 07, 2012
Does ffbd2411ns have a thermal fuse?
Good Afternoon friend, thanks for your post!
I understand that you are searching for the thermal fuse within your Frigidaire dishwasher, FFBD2411NS. I checked over your parts manual and was unable to locate any thermal fuse. Is your dishwasher not heating up? What issues are you having with your dishwasher? Any further information and I would be able to assist you further. -Matt
Feb 16, 2015 | Frigidaire Dishwashers
Where is the thermal fuse located on a frigidarie affinty dryer model # faqg7021wl0
Good Afternoon Friend, this is Z. I am happy to assist you!
The thermal fuse on your Frigidaire dryer (FAQG7021WL0) is typically located on the outlet duct. However, I show that this model also has another thermal fuse located on the flame housing. Hope this helps!
Jun 03, 2014 | Frigidaire Dryers
I can't find where the fuses are on model FDE/FDG336RE
There is no thermo-fuse on this model, only a cycling and safety thermostat.
Oct 08, 2013 | Frigidaire Dryers
Dryer is not turning on
That sounds like a bad door switch to me. My Frigidaire dryer service manual and more is HERE
Nov 27, 2012 | Frigidaire Dryer Thermal Fuse Thermal...
Where are the fuses located on frigidaire fex831cs
Hello April Tucker - Generally speaking, Frigidaire laundry centers do not have fuse. The unit has a thermal limiter usually located in the dryer.
Oct 06, 2012 | Frigidaire FEX831CS Top Load Stacked...
Were is the thermal fuse located on the frigidaire fde336res1
Jul 07, 2012 | Frigidaire Dryers
My frigidaire dryer keeps pausing itself and won't dry the clothes.
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Mar 09, 2011 | Frigidaire Washing Machines
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
How do you remove the back od dryer to get to the drum? Model # FDE/FDG336RE
you dont remove the back the drum comes off with a pop up and out of the plastic roller in the back or 3 philips head screws in the rear of the drum
Nov 07, 2010 | Frigidaire FDE336RE Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
