Question about Daewoo DVRS04 DVD Recorder/VCR
How to enable country code on Daewoo SG-9J00 - Daewoo DVRS04 DVD Recorder/VCR
How to enable printer option in canon iR3225
http://support-sg.canon-asia.com/contents/SG/EN/0300451201.html
download file
and run it
it will extract files to an irc3225 folder in your download folder
run index.html file
and
it has a section on printing where it explains how to achieve printing
Jul 30, 2016 | Canon imageRUNNER 3225 Black and White...
I need a vacuum lay out for nubira 2000
what country, all cars , in all countries have different smog laws
and bingo different vacuum parts.
next is what engine, most cars have 2 to 10 engine options or worst you county has a special engine, again, smog regs , and laws.
year car, 2000
Maker Daewoo (left USA long ago)
Nubira
engine size.
country.
bingo?
if that is too hard. the go to the dealer and to the parts counter
and ask for the FSM, (factory service manual) its all there.
May 20, 2014 | 2000 Daewoo Nubira
I'm trying to find the unlock codes for the stereo
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Daewoo service centre andget them to enter this code for you.
Feb 03, 2012 | 2001 Daewoo Tacuma 2.0
I have 11 year old Daewoo matiz SG car. Run only 72000km. Now the problem is if switch on the AC , the car will not take lod if travel four peoples if the car in First gear also can not able to drive. The...
Did you ever check your spark plug. Change all 4 and your high tension wire might also defective. If your already done this procedure then your clutch might be worn out. This mean your clutch is sliding. Or your engine need tune up means need adjustment on the valve inside the engine
Sep 08, 2011 | Daewoo Lanos Cars & Trucks
Where do i enter my code #
Hello.
Not certain of your question, but first, set up a single PC to connect to the SG565 unit. Information is entered from that PC.
The initial steps are:
1 Connect your administrative PC to the SG unit:
- If you are setting up the SG560, SG565 or SG580, attach your
PC's network interface card directly any network port on switch A
(A1 - A4) using the supplied network cable.
2 Modify your PC's network settings to enable communication with the
SG unit. Click Start > (Settings >) Control Panel and double-click
Network Connections. Right-click Local Area Connection and
click Properties.
Note: If there is more than one existing network connection, select the
one corresponding to the NIC to which the SG unit is attached.
3 Select Internet Protocol (TCP/IP) and click Properties. The
Internet Protocol (TCP/IP) Properties dialog box is displayed.
4 Select Use the following IP address and enter:
- IP address: 192.168.0.100
- Subnet mask: 255.255.255.0
- Default gateway: 192.168.0.1
5 Select Use the following DNS server addresses and enter
Preferred DNS server: 192.168.0.1
6 Click OK and Close
Hope this helps.
Jan 20, 2011 | SG565 (SG0186US) Firewall
I am getting e3 error code every 30 minutes with my lg conditioner
E-3 Remote controller comms error. Check wired correctly, if so check dipswitch in RC. Set to Sg for 1 unit, or Gr for group then reset power
Apr 29, 2010 | Daewoo DWC-060C Air Conditioner
I NEED A CODE FOR MY RADIO CAN YOU SOLVE THIS MY BATTIER WHEN DEAD AND WHEN TURNING ON THE CAR AFTER I GOT IT RECHARGED UP IT NEEDED A FOUR DIGIT CODE
Following are 15 individual, 4 digit codes:
4316, 2152, 4513, 4362, 1156, 2145, 3451, 6361, 5624, 5241, 3346, 1165, 3241, 4524, 5436
Feb 15, 2010 | 2000 Daewoo Leganza
Running problem in monsoon season in Daewoo Matiz.
Has the clutch been replaced recently? There is an earth wire under one of the bell housing bolts,if not refitted can cause all sorts of problems.
Jul 19, 2009 | 2000 Daewoo Lanos
Region free code
Hi...put in the DVD then press 1 3 7 9...they will appear as xxxx...then press country code...it will appear as digit, then press " play"
Oct 01, 2006 | Daewoo DVG-8500N DVD Player
Daewoo DVRS04 DVD Recorder/VCR Logo
24 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
