Question about Panasonic DMP-BD30K Blu-Ray Player
When I press any button on remote it says set 2 and i can't fast forward etc
  • Panasonic Master
  • 508 Answers
You could try resetting the remote itself (remove the batteries as if to replace them, press any key on the remote to clear its buffer, then re-insert them or use new batteries) - since your unit is on remote command 2 (or SET 2), try pressing 2 and ENTER/OK on the remote together for 10 seconds, then release. This should now restore your remote to the correct command mode for your player. It may also solve the playback function issue.
The remote for most Panasonic DVD units would need to be reset whenever the batteries are replaced.
I understand the instruction manual does not always help the user.
Posted on Apr 08, 2011
How do I set the clock on my Panasonic SA-Ak270 mini stereo
The main unit is the SA-AK270. The entire mini-system is called the SC-AK270. The manual is available on the Panasonic support site: https://www.panasonic.com/au/support/manual-download/audio/hi-fi/sc-ak270.html . You do need to accept the Panasonic terms of use to download the manual. The check box is below the box with the Manual description and View link. The clock setting procedure is shown on page 14 (with the remote). The pictures of the remote control and main unit buttons are on pages 8-9 of the manual.
With the remote, press the Clock/Timer button until the Display is showing the time. Press Skip Back/Rewind or Skip Forward/Fast Forward within 8 seconds of pressing Clock/Timer to set the hour. Press Clock/Timer again and use the same Rewind/Fast Forward buttons to set the minutes. Note: the SC-AK270 uses a 24-hour clock.
You can also do this by starting with the Display button on the main unit. Then use the Skip Back/Rew and Skip Forward/Fast Forward buttons on either side of the Manual Eq button.
I hope this helps.
Mar 07, 2018 | Panasonic Audio Players & Recorders
How do you program into the dvd that you want it to fast forward quickly? There is a way but am not sure how it is done.
You don't, you just press the FORWARD button on remote during DVD playback to 'fast forward' (pressing this button a second time during playback increases forward scan speed). The forward and reverse buttons have 'SLOW/SEARCH' printed above them on the remote. The other buttons next to them are the PREV/NEXT buttons (SKIP/INDEX).
DVD playback speed/skip/search is mostly a manual user function; it cannot be auto set.
May 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I can't seem to be able to fast forward any more than twice speed. I know there is some way I can program it that it allows me to be able to do that but I can't seem to find in the manual where I...
Hi Henry,
  1. Usually DVD players DVD players come along with remote controls which have fast forward buttons which have the icon as ">>" .
  2. All you need to do , is press the button as per your requirement of fast forwarding.
  3. If you press the one, you would get a message as x2 on the TV screen and if you again press it , it would display x3 and if you press the button again it would show x4 , that is the maximum speed you can have usually for fast forwarding.
  4. So the solution is to keep pressing the button multiple times to change the fast forward speed.
Hopet his helps ...Your feedback would be appreciated.
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
I need the universal codes for my verizon fios remote, otherwise another recommendation of a universal remote that will operate my tv.
Setting up the Philips RC 144 remote if the remote codes are invalid or unknown If you do not know the remote codes for a device, or if you've tried all the listed remote codes for your device and none of them work, you can search for the correct remote code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Feb 28, 2011 | Apex Digital LD4088 LCD TV
When tv 1 is on, I do not have control on t.v. 2 with the remote to change channels fast forward or rewind.
Hi dhperezfamilmy name is Mike Houston of DISH Network and I was going over your post and withyour TV2 remote not working while TV1 is on there is a conflict between theremotes. What you will need to do is on TV1 remote press the MENU button 2 timesand it will take you to the System Info screen. On the TV2 remote press andrelease the SAT button and press the Record button one time and then press theselect button on the remote.
Feb 11, 2011 | DISH Network IR Remote Control
IHAVE REMOTE PX-RC1 ILOSE THE CODE BOOK & TV NAME PRIMA
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED should stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. Then press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.
Dec 24, 2010 | Universal Remote Control MX-500 LCD Remote...
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Aug 29, 2009 | Samsung DVD-H1080 DVD Player
Fios code for Winbook TV
If you do not know the device codes for a device, or if you've tried all the listed device codes for your device and none of them work, you can search for the correct device code by following the steps below.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of thePlay button.
  7. Note:
Feb 11, 2009 | Zenith ZN-501S Remote Control
Ineed a manual for a Fisher VCR
This may help.
Hold down tv power enter the 2 digit code using number buttons 0-9 then release tv power button
Admiral 05, 10 13 - Emerson 17 - Fisher 03 – GE 07 – Gold Star 01 – Hitachi 02 – JVC 15 – Magnavox 08 – Matsushita 12, 18 - Mitsubishi 14 – Panasonic 12, 18 - Quasar 12, 18 – RCA 06 – Samsung 16 – Sanyo 03 – Sharp 00, 13 - Sony 11 – Technolace 05 – Toshiba 04 – Zenith 09,10
And now the impossible clock setting. Turn unit on press clock while holding down the shift button. Press fast forward or rewind to change hours, then press adjust while holding down shift button to select the minutes again use the fast forward or rewind arrows to change minutes then again the adjust and shift combo to start clock.
Good luck Kevin
Fishers help line is 1-800-421-5013
Jan 29, 2008 | Televison & Video
Panasonic DMP-BD30K Blu-Ray Player Logo
1,077 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
