Wont start up, says CHK and then ERR, have tried the disp/menu and stop for 2 seconds and it comes up with In VAL, any ideas on how to fix this?
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this task will schedule when computer restarts which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive do nothing while the chkdsk utility ani input may damage your computer then defragment your hard drive then you might
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
you can do any of these options at any time
hope this helps
Posted on Apr 08, 2011
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
Screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Feb 01, 2010 | Olympus VN-4100PC Digital Voice Recorder
My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Dec 16, 2009 | Olympus VN-3100PC Digital Voice Recorder
ERR
Solution is very simple - just press DISP/MENU and STOP simultaneously for 2-3 seconds. There will start the FOR blinking on the screen of recorder (ERR will disappear) and the red "eye" on the switchboard. Wait for few minutes and your recorder is back to work :)
Warnning: This means FULL restart and you will lose ALL your recorded data! But I did not find any other solutions...
Apr 14, 2009 | Olympus VN-4100PC Digital Voice Recorder
Mensage ERR, not start
Press the DISP/MENU and STOP buttons at the same time for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Feb 15, 2009 | Olympus VN-4100PC Digital Voice Recorder
"chk" error on screen olympus vn-4100 pc
I had a similar sounding problem my Olympus VN-5000. I would turn it on, it would show "CHK" for a few seconds, and then "ERR." This persisted despite fresh batteries. The "ERR" message reportedly means a memory error. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model...
Jul 20, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC Voice Recorder Problem
I fought with this machine for more than 9 months. And after playing with it today FINALLY got it working.
This is what I did:
Unscrew the faceplate. (Three screws. One is under the batteries).
Put the batteries back on.
Have the HOLD button on the normal position (down)
Press and hold the MENU/FOLDER button together with the STOP button
Press and hold the MENU/FOLDER button together with the DISPLAY button
You will see a GREEN light, then a RED light then a "FOR" message will appear
Press the DISPLAY button and after a few moments it will reset and ask you to enter the time.
GOOD LUCK. Let me know if it works for you.
HAVE A NICE DAY.
Jul 15, 2008 | Olympus VN-3100PC Digital Voice Recorder
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Jun 25, 2008 | Olympus VN-240 Digital Voice Recorder
Error message
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
May 26, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-2100PC Error Message 'chk' and then 'Err'
Hello evrybody,
I had the same problem but i fix it.
This is the solution :
1- When the "ERR" message is shown, press Disp/Menu Buton for Two seconds and at the same time "Stop" Buton.
2- The "FOR" Message is shown
3- wait for some minutes
That's all
PS : All the recrded messages will be deleted
Sep 21, 2007 | Olympus VN-2100PC Digital Voice Recorder
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
