Question about LaCie Big Disk External USB 2.0 1TB Hard Drive
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
    Problem Solver:
  • 13 Answers
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Posted on Apr 08, 2011
My iMac does not recognize the Lacie 1tb big disk extreme external hard drive. No icon appears.
the first step will be to verify your power supply. When it is plugged to the wall power outlet, it should be silent (no hissing or high pitch noise) and the green light should be on on the power supply.. If it is not the case, replacing it might solve your problems.
Second step is to verify if it is an interface problem. Try using a different port on the drive.
If no success, start Disk Utility and look to the left if you have any mention of a drive of 1TB. If you do, the partition of your drive might be corrupted. You can try running First Aid from Disk utility if its available, else you will need to try a partition repair software or a Data recovery program.
There are a few available that you can get a free copy to see if the data is available before you buy.
Regards,
Jan 07, 2011 | LaCie Big Disk Extreme with Triple...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
I need a new AC Power Supply for my 2T LaCie external hard drive.
Call LaCie. Your drive may be eligible for extended warranty support where your power supplies may be replaced FOR FREE.
Jul 07, 2009 | LaCie 301294U 1TB Big Disk Extreme + with...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Open Questions:
LaCie Big Disk External USB 2.0 1TB Hard Drive Logo
500 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
